GL-A1300 (Slate Plus) PPPoE Connection Failure
Problem Description
My new GL-A1300 router is unable to establish an internet connection. The system log consistently shows that the PPPoE discovery process fails with the error: Timeout waiting for PADO packets .
This issue is specific to the GL-A1300. I have an older GL-XE300 router that connects to the exact same internet line, using the exact same cables and PPPoE settings (username, password, VLAN 200), and it works perfectly.
Environment:
ISP Connection Type: PPPoE
Required VLAN ID: 200
ONT: Genexis Fibertwist P2411
Key Finding & Analysis
The critical difference between the two routers is the WAN port link speed:
  • The GL-A1300 (failing) negotiates a 1Gbps link, but the PPPoE handshake never completes.
  • The GL-XE300 (working) negotiates a 100Mbps link, and the PPPoE connection is established successfully.
This strongly suggests there is a hardware-level incompatibility or a firmware/driver bug on the GL-A1300 that prevents it from correctly handling PPPoE discovery packets over a tagged VLAN when the link speed is 1Gbps.
Troubleshooting Steps Performed
I have performed extensive troubleshooting to isolate the issue:
  1. Updated Firmware: The GL-A1300 is running the latest stable firmware.
  2. Factory Reset: I have performed multiple factory resets and configured the connection from scratch each time.
  3. MAC Cloning: I have cloned the MAC address from the working GL-XE300 onto the GL-A1300. The issue persists.
  4. Intermediate Switch: I placed a simple unmanaged gigabit switch between my ISP's modem and the GL-A1300's WAN port. This did not solve the problem.
  5. Forcing Link Speed: I attempted to manually force the WAN port (eth1 ) to 100Mbps using the ethtool command via SSH. However, the router's network management daemon (netifd ) overrides this setting on every connection attempt, forcing the link back to 1Gbps.
Conclusion
The problem is isolated to the GL-A1300 router. All evidence points to a bug in the firmware or network driver that affects PPPoE negotiation on a tagged VLAN at 1Gbps speeds.
Could you please investigate this issue?
Can you turn on the router, reconnect to the PPPOE line, wait for a while, export the router log and PM it to me?
