GL-A1300 travel router can't see devices on GL-AX1800 home router
I have the GL-AX1800 router installed at my home with all my devices wired to it. I travel with the GL-A1300 travel router, and have port forwarded my ISP router to give me a VPN tunnel, but I am not able to see or access the other devices on the network.
Please share additional information about your network topology, see How to get support quickly
How is VPN dashboard set up? (There are many options)
While you communicate/drive through a tunnel you cannot see what is outside this tunnel except via the entry/exit points.
Global Proxy
If the VPN is connected, all traffic will be routed through the VPN. Only one VPN client instance can be activated.
I setup Wireguard on the VPN dashboard. I have enabled Remote Access LAN, IP Masquerading, and Client to Client.
  • Which router (which model?) are you using? GL-AX1800 (Home) GL-A1300 (Travel)
  • Which firmware version is in use? GL-AX1800 v4.6.8 , GL-A1300 v4.5.19
  • How is your router connected to the Internet? By cable via the Cox panoramic router from Cox cable
  • Which DNS server do you use? Adguard
  • Do you use DHCP or static IP addresses? DHCP
I assume you probably did set up "Wireguard server" on the GL-AX1800 and the GL-A1300 is the "Wireguard client".
Would you need routing rules at the AX1800? Depends on the network there.
