GL-A1300 Wireguard Client setup for NAS hosted Wireguard server
I've recently stumbled across the GL.iNet router line up and I was in the market for something small which I would be able to leave onsite to allow me to connect back to my home network to access files on my nas (running unraid).
The Wireguard setup on the unraid side was simple enough, following a guide I was able to set the server configured with dynamic DNS and required port forwarding. To test thing initially I've downloaded the Wireguard app for my iPhone, disconnected from my home Wi-Fi (so using 5G), imported the VPN config and everything has worked as I would intend, I have access to the NAS/Shares.
I've then followed a guide for the basic setup of the A1300 and have connected by iPhone to the wireless on the A1300. I've configured the VPN client settings, the VPN connects and I can see the client showing up as connected on my NAS (given updates to last handshake time etc) and the ball is green within A1300 UI, however I can't access anything from my phone browser.
My intended config is that I can plug the A1300 into an existing Virgin media router (192.168.0.x via DHCP), then present a Wi-Fi SSID which I can connect a FireTV Stick or Laptop to for access to media / server on my network.
Is there something I'm missing to enable to above scenario?
Please read How to troubleshoot WireGuard maybe it will help you already :slight_smile:
On A1300, does wireguard has data going through?
Can you check the dns settings as in @admon's guide
