I just purchased a Slate Plus, but when I try to connect it to wifi to act as a repeater it fails continuously.
During the first connection it discovers the network - but fails to connect. In automated repeating connection attempts the UI says it fails to discover the network.
Some failures/warnings are included in the logs but I can't make heads or tails of them. Can anyone assist?
This is the way how it works for my GL-A1300 FW 4.5.16 in every hotel, wether they use password or captive portal. I fix it to 2.4 GHz, 20 MHz BW and connect to it on channel 155 80MHz BW.
I use the GL-A1300 since many month in abt. 15 hotels with wireguard VPN to my FritzBox at home. It works perfectly without any problems or unintended interruptions.
