Azndfc
November 25, 2020, 11:06pm
21
I have updated the firmware by drag n drop. Now that it has been updated, I cant access it via the usual 192.168.8.1 or via the previous IP (I set it at 10.10.10.10).
It is connected but the settings cant be accessed via IP. Do you know the IP @alzhao ?
alzhao
November 26, 2020, 4:48am
22
what is the IP address you got on your pc?
You can simply reset the router by press and hold the reset button for 10 seconds. But all of your settings will be cleared.
Azndfc
November 26, 2020, 9:18am
23
I have reset my router before. Now I tried it again and it doesnt work.
I accessed the router using 192.168.8.1 but is failed.
alzhao
November 27, 2020, 2:34am
24
I understand what you are saying. But the first thing to check is the LED status and the IP you got on your pc.
Pls check this video guide about how to find your IP on windows.
Azndfc
November 27, 2020, 9:58pm
25
Thanks. The IPV4 Default Gateway is correct. I still can’t access it via 192.168.8.1 though.
I guess I have to de-brick it? CMIIW
alzhao
November 30, 2020, 8:02am
26
Seems this is fine. Do not need to debrick.
Do you have vpn turnning on the pc?
Do you have Internet?
Can you ping 192.168.8.1 or 1.1.1.1 on your pc?
Azndfc
March 1, 2021, 10:33pm
27
I can ping both IP on my usual internet, but cannot ping when connected to GL Inet.
No I don’t use VPN…
alzhao
March 3, 2021, 11:49am
28
I can determine the reason.
Can we set up a remote check using anydesk?
Azndfc
March 18, 2023, 11:41pm
29
Hello, sorry I disappeared @alzhao
If you can kindly check my router, will it be possible?
alzhao
March 20, 2023, 7:56am
30
As all info is 2 years old. Please send your request with details to support at glinet.biz
We will reply from there
Azndfc
March 20, 2023, 8:28am
31
I already using unbrick method and install the new firmware all over. Thanks for your response
