With the previous software version there was the possibility to connect a USB Web cam to the GL-AR150! With the latest OS can the USB Web Cam be connected and viewed remotely? Or do we need to install a package.
Sorry but am I supposed to be doing this via telnet or a terminal?
You login to your router via SSH and run the commands in the post @rp201rp posted for you ![]()
There is a guide like usual in the documentation here:
http://192.168.8.1
login
go to applications-plugins and click update.
then search and install each individual plugin:
kmod-video-gspca-sonixb
kmod-video-gspca-sonixj
kmod-video-gspca-zc3xx
kmod-video-uvc
luci-app-mjpg-streamer
So after installing the above plugins. plugin your camera and go to
http://192.168.8.1/cgi-bin/luci/admin/services/mjpg-streamer
click enable and select input=uvc and output=http port=8080
then goto http://192.168.8.1:8080
