Hello, i have an GL-AR150 with an usbstick that gives internet trough 4G.
The idea is give support to a remote device.
Best idea is router have VPN server with DDNS.
On my computer connect the VPN and get access to the lan of the router.
I have problems with DDNS on my GL-AR150.
test results said:
Your DDNS is resolved as 176.83.10.209
But this router is behind NAT or you do not have a Public IP address.
Also have problems with the OpenVpnServer, i generate the file.
But when i use the client said that key is not configured.
I found that my USB modem work in host-less mode.
Then i had to confirure it as tethering, thats why VPN detects a NAT.
Here is the explanation.
On the same page is a devide list with compatible 3G-4G modems and my device is on the list:
HUAWEI - E3372
and is also recomended as “regular modem” on this page: http://ofmodemsandmen.com/modems.html
Can you help me to solve this problem?
i purchase everything as recomended and i cannot use the device as it was planned to.
Thank you very much.
