I cannot ssh into the router because after the factory reset it doesn’t broadcast SSID. I also am unable to connect to it via Ethernet at the default config page 192.168.8.1
But can you ssh to 8.1? Download putty and try this before giving up. Also try ping 192.168.8.1 when manually adding your computer’s lan interface on this range, lik 8.4
