after updating my GL-AR150 to firmware 3.105 i can not access the advanced options.
The error is:
/usr/lib/lua/luci/dispatcher.lua:230: /etc/config/luci seems to be corrupt, unable to find section ‘main’
stack traceback:
[C]: in function ‘assert’
/usr/lib/lua/luci/dispatcher.lua:230: in function ‘dispatch’
/usr/lib/lua/luci/dispatcher.lua:127: in function </usr/lib/lua/luci/dispatcher.lua:126>
This is reproducible.
If I go back to firmware 3.017 everything ist ok.
After update to 3.105 i have this error. No matter if i make the update manual, or online.
Hello alzhao,
i found a solution.
In the GUI i made a “revert firmware” to factory default settings.
Then i made the update, and now i can acess luci even in firmware version 3.105.
But now there is a new problem.
In firmware 3.105 it is not possible to choose channels higher than 11.
I have changed the country code to Germany in Luci. In luci i can even select channel 12 and 13.
But in te GUI they do not appear in the overview.
If i go back to firmware 3.017 everything works. After updating to 3.105 channels 12 and 13 dissapear in the GUI.
