i have a problem with connecting 2 PCs over different VPN-enabled routers. We are using OpenVPN.
The routers are configured as shown in the Picture. From PC B you can access all components via the VPN IP.
The connection from PC A to the GL-AR150 Router is possible. But there is no connection to PC B.
I assume, that I have to configure Port Forwarding or Firewall Settings. Can you help me, how this can be done with the GL-AR 150?
