I have two GL-AR150 Routers, both with 5dBi antennas. Since about 1 week one of the routers has suddenly stopped returning any results when scanning for wireless networks. Screenshot 1 shows nearby WiFi networks which my Mac detects readily, but the GL-AR150 doesn’t. The router is right next to my laptop. Screenshot 2 shows the output from the command line when I run the “iwlist scan0 scan” command. Basically tells me that the Interface doesn’t support scanning.
To note - the other GL-AR150 is running just fine, and all the scanning functions work properly.
I have performed the necessary factory resets, re-uploaded the latest firmware, etc.
If you need any specific troubleshooting output, I will be happy to provide it.
I re-flashed the router to the latest firmware (2.24) a while ago, and cleared out all the saved configurations when re-flashing the firmware. It has now gone back into its default settings, with the IP address 192.168.8.1, and the SSID GL-AR150-357.
I tried the Wireless Scan again, with no luck. The attached screenshots show the results of the router before and after the wireless scan, and the attached text file contains the outputs of the commands you mentioned, plus a few more that I thought might come in handy for diagnosis.
@alzhao, Yes, I can use it as a normal WIFI Access Point, and I can connect to it from my computer and even plug it into my wired Ethernet to route packets and everything. As a WIFI Access Point, it is functioning perfectly well. The antenna connection is also good. I replaced the antenna with the other GL-AR150’s antenna to test as well, and both antennas work just fine. If there is any internal or physical test you would like me to perform, I can do that too.
