This is my 2nd GL AR300 and I am trying to set it up. I had ssh port forwarding enabled on port 2222. I have added my pub key to /root/.ssh/authorized_keys. When I try to ssh, I am still prompted for password. My old AR300 had pre-LEDE build on it. The ssh worked with public key flawlessly.
I spent an hour so far trying to get this working, but making no progress. Appreciate any help.
Below is how I uploaded public key:
[~/work/glinet] ssh-copy-id -i ~/.ssh/id_rsa -p 2222 [email protected]
/usr/bin/ssh-copy-id: INFO: Source of key(s) to be installed: “/c/Users/droidvideo/.ssh/id_rsa.pub”
/usr/bin/ssh-copy-id: INFO: attempting to log in with the new key(s), to filter out any that are already installed
/usr/bin/ssh-copy-id: INFO: 1 key(s) remain to be installed – if you are prompted now it is to install the new keys
[email protected]’s password:
Number of key(s) added: 1
Now try logging into the machine, with: “ssh -p ‘2222’ ‘[email protected]’”
and check to make sure that only the key(s) you wanted were added.
[~/work/glinet]
[~/work/glinet] ssh -p ‘2222’ -i ~/.ssh/id_rsa ‘[email protected]’
Thanks
