I had not used my ar300m for a while, and fired it up last night to make sure it was still OK. While I was making sure it was OK, I updated to firmware 2.27. The device is still working Ok, but now it seems to only boot into the NOR firmware now. I have tried reverting to the factory default, but the device remains on 2.27.
I have also tried uploading/flashing the prior firmware (2.261, 2.264) but receive the message " Error: Firmware is not for this hardware."
The WiFi now shows default ID as GL-A300M-b0f-NOR.
How can I return this device to the previous state of booting into NAND?
I do not think it is “bricked” as it works fine - I simply cannot get it to boot into NAND (does that qualify as being “bricked”?). Can you verify that the solution you have provided fits this particular situation? I normally define bricked as being totally inoperable.
And, FYI, I have tried just about everything I could find on this forum (and others) and nothing has worked so far.
