GL-AR300M connection drop
There was a recent software upgrade for my GL-AR300 M router and since then i am facing a connection drop issue every 2 hours on the same time.
Please advise if some one is facing similar issue.
Version - v4.3.25
below are some systems logs for reference
Fri Apr 25 06:59:00 2025 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.140 3a:e2:09:b2:64:53 OnePlus-11-5G
Fri Apr 25 07:16:33 2025 daemon.notice wpa_supplicant[2021]: wlan-sta0: CTRL-EVENT-BEACON-LOSS
Fri Apr 25 07:16:33 2025 daemon.info lua: (...db/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-BEACON-LOSS
Fri Apr 25 07:16:33 2025 daemon.notice netifd: Network device 'wlan-sta0' link is down
Fri Apr 25 07:16:33 2025 daemon.notice netifd: Interface 'wwan' has link connectivity loss
Fri Apr 25 07:16:33 2025 daemon.notice wpa_supplicant[2021]: wlan-sta0: CTRL-EVENT-DISCONNECTED bssid=a8:88:1f:06:28:c2 reason=4 locally_generated=1
Fri Apr 25 07:16:33 2025 daemon.info lua: (...db/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-DISCONNECTED bssid=a8:88:1f:06:28:c2 reason=4 locally_generated=1
Fri Apr 25 07:16:33 2025 daemon.info lua: (...db/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-SCAN-STARTED
Fri Apr 25 07:16:33 2025 daemon.notice netifd: wwan (32409): udhcpc: received SIGTERM
Fri Apr 25 07:16:33 2025 daemon.notice netifd: wwan (32409): udhcpc: unicasting a release of 192.168.29.9 to 192.168.29.1
Fri Apr 25 07:16:33 2025 daemon.notice netifd: wwan (32409): udhcpc: sending release
Fri Apr 25 07:16:33 2025 daemon.notice netifd: wwan (32409): udhcpc: entering released state
Fri Apr 25 07:16:33 2025 daemon.notice netifd: wwan (32409): Command failed: ubus call network.interface notify_proto { "action": 0, "link-up": false, "keep": false, "interface": "wwan" } (Permission denied)
Fri Apr 25 07:16:33 2025 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.wg
Fri Apr 25 07:16:33 2025 daemon.info dnsmasq[1]: using nameserver 1.1.1.1#53
Fri Apr 25 07:16:33 2025 daemon.info dnsmasq[1]: using nameserver 1.0.0.1#53
Fri Apr 25 07:16:33 2025 daemon.info dnsmasq[1]: using only locally-known addresses for test
Fri Apr 25 07:16:33 2025 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Fri Apr 25 07:16:33 2025 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Fri Apr 25 07:16:33 2025 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Fri Apr 25 07:16:33 2025 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Fri Apr 25 07:16:33 2025 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Fri Apr 25 07:16:33 2025 daemon.notice netifd: Interface 'wwan' is now down
Fri Apr 25 07:16:33 2025 daemon.notice netifd: Interface 'wwan' is disabled
Fri Apr 25 07:16:33 2025 daemon.notice netifd: Interface 'wwan' is enabled
Fri Apr 25 07:16:34 2025 daemon.info lua: (...db/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-SCAN-RESULTS
Fri Apr 25 07:16:34 2025 daemon.info lua: (...db/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:548) <3>WPS-AP-AVAILABLE
Fri Apr 25 07:16:34 2025 daemon.notice wpa_supplicant[2021]: wlan-sta0: SME: Trying to authenticate with a8:88:1f:06:28:c2 (SSID='JioFiber-1504-4G' freq=2412 MHz)
Fri Apr 25 07:16:34 2025 daemon.info lua: (...db/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:548) <3>SME: Trying to authenticate with a8:88:1f:06:28:c2 (SSID='JioFiber-1504-4G' freq=2412 MHz)
Fri Apr 25 07:16:34 2025 kern.info kernel: [16728.124102] wlan-sta0: authenticate with a8:88:1f:06:28:c2
Fri Apr 25 07:16:34 2025 kern.info kernel: [16728.130404] wlan-sta0: send auth to a8:88:1f:06:28:c2 (try 1/3)
Fri Apr 25 07:16:34 2025 kern.info kernel: [16728.147903] wlan-sta0: authenticated
Fri Apr 25 07:16:34 2025 daemon.notice wpa_supplicant[2021]: wlan-sta0: Trying to associate with a8:88:1f:06:28:c2 (SSID='JioFiber-1504-4G' freq=2412 MHz)
Fri Apr 25 07:16:34 2025 daemon.info lua: (...db/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:548) <3>Trying to associate with a8:88:1f:06:28:c2 (SSID='JioFiber-1504-4G' freq=2412 MHz)
Fri Apr 25 07:16:34 2025 kern.info kernel: [16728.191958] wlan-sta0: associate with a8:88:1f:06:28:c2 (try 1/3)
Fri Apr 25 07:16:34 2025 kern.info kernel: [16728.210657] wlan-sta0: RX AssocResp from a8:88:1f:06:28:c2 (capab=0x411 status=0 aid=3)
Fri Apr 25 07:16:34 2025 kern.info kernel: [16728.219399] wlan-sta0: associated
Fri Apr 25 07:16:34 2025 daemon.notice netifd: Network device 'wlan-sta0' link is up
Fri Apr 25 07:16:34 2025 daemon.notice netifd: Interface 'wwan' has link connectivity
Fri Apr 25 07:16:34 2025 daemon.notice netifd: Interface 'wwan' is setting up now
Fri Apr 25 07:16:34 2025 daemon.notice wpa_supplicant[2021]: wlan-sta0: Associated with a8:88:1f:06:28:c2
Fri Apr 25 07:16:34 2025 daemon.info lua: (...db/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:548) <3>Associated with a8:88:1f:06:28:c2
Fri Apr 25 07:16:34 2025 daemon.notice wpa_supplicant[2021]: wlan-sta0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Fri Apr 25 07:16:34 2025 daemon.info lua: (...db/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Fri Apr 25 07:16:34 2025 daemon.notice wpa_supplicant[2021]: wlan-sta0: WPA: Key negotiation completed with a8:88:1f:06:28:c2 [PTK=CCMP GTK=CCMP]
Fri Apr 25 07:16:34 2025 daemon.info lua: (...db/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:548) <3>WPA: Key negotiation completed with a8:88:1f:06:28:c2 [PTK=CCMP GTK=CCMP]
Fri Apr 25 07:16:34 2025 daemon.notice wpa_supplicant[2021]: wlan-sta0: CTRL-EVENT-CONNECTED - Connection to a8:88:1f:06:28:c2 completed [id=0 id_str=]
Fri Apr 25 07:16:34 2025 daemon.info lua: (...db/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-CONNECTED - Connection to a8:88:1f:06:28:c2 completed [id=0 id_str=]
Fri Apr 25 07:16:35 2025 daemon.notice netifd: wwan (18149): udhcpc: started, v1.35.0
Fri Apr 25 07:16:35 2025 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.wg
Fri Apr 25 07:16:35 2025 daemon.info dnsmasq[1]: using nameserver 1.1.1.1#53
Fri Apr 25 07:16:35 2025 daemon.info dnsmasq[1]: using nameserver 1.0.0.1#53
Fri Apr 25 07:16:35 2025 daemon.info dnsmasq[1]: using only locally-known addresses for test
Fri Apr 25 07:16:35 2025 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Fri Apr 25 07:16:35 2025 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Fri Apr 25 07:16:35 2025 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Fri Apr 25 07:16:35 2025 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Fri Apr 25 07:16:35 2025 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Fri Apr 25 07:16:35 2025 daemon.notice netifd: wwan (18149): udhcpc: broadcasting discover
Fri Apr 25 07:16:35 2025 daemon.notice netifd: wwan (18149): udhcpc: broadcasting select for 192.168.29.9, server 192.168.29.1
Fri Apr 25 07:16:36 2025 user.notice mwan3[18052]: Execute ifdown event on interface wwan (unknown)
Fri Apr 25 07:16:36 2025 user.info mwan3track[739]: Detect ifdown event on interface wwan (wlan-sta0)
Fri Apr 25 07:16:36 2025 user.notice mwan3track[739]: Interface wwan (wlan-sta0) is offline
Fri Apr 25 07:16:38 2025 daemon.notice netifd: wwan (18149): udhcpc: broadcasting select for 192.168.29.9, server 192.168.29.1
Fri Apr 25 07:16:38 2025 daemon.notice netifd: wwan (18149): udhcpc: lease of 192.168.29.9 obtained from 192.168.29.1, lease time 82800
Fri Apr 25 07:16:38 2025 daemon.notice netifd: Interface 'wwan' is now up
Fri Apr 25 07:16:38 2025 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.auto
Fri Apr 25 07:16:38 2025 daemon.info dnsmasq[1]: using nameserver 192.168.29.1#53
Fri Apr 25 07:16:38 2025 daemon.info dnsmasq[1]: using only locally-known addresses for test
Fri Apr 25 07:16:38 2025 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Fri Apr 25 07:16:38 2025 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Fri Apr 25 07:16:38 2025 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Fri Apr 25 07:16:38 2025 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Fri Apr 25 07:16:38 2025 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Fri Apr 25 07:16:38 2025 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.wg
Fri Apr 25 07:16:38 2025 daemon.info dnsmasq[1]: using nameserver 1.1.1.1#53
Fri Apr 25 07:16:38 2025 daemon.info dnsmasq[1]: using nameserver 1.0.0.1#53
Fri Apr 25 07:16:43 2025 user.notice firewall: Reloading firewall due to ifdown of wwan ()
Fri Apr 25 07:16:48 2025 user.notice mwan3[18891]: Execute ifup event on interface wwan (wlan-sta0)
Fri Apr 25 07:16:49 2025 user.notice mwan3[18891]: Starting tracker on interface wwan (wlan-sta0)
Fri Apr 25 07:16:49 2025 user.notice mwan3track[739]: Stopping mwan3track for interface "wwan"
Fri Apr 25 07:16:54 2025 user.info mwan3rtmon[4629]: Detect rtchange event.
Fri Apr 25 07:16:56 2025 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta0)
Fri Apr 25 07:17:01 2025 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED 28:6b:35:b2:00:89
Fri Apr 25 07:17:33 2025 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED 3a:e2:09:b2:64:53
Fri Apr 25 07:17:33 2025 daemon.info hostapd: wlan0: STA 3a:e2:09:b2:64:53 IEEE 802.11: disassociated due to inactivity
Fri Apr 25 07:17:34 2025 daemon.info hostapd: wlan0: STA 3a:e2:09:b2:64:53 IEEE 802.11: authenticated
Fri Apr 25 07:17:34 2025 daemon.info hostapd: wlan0: STA 3a:e2:09:b2:64:53 IEEE 802.11: associated (aid 3)
Fri Apr 25 07:17:34 2025 daemon.notice hostapd: wlan0: AP-STA-CONNECTED 3a:e2:09:b2:64:53
Fri Apr 25 07:17:34 2025 daemon.info hostapd: wlan0: STA 3a:e2:09:b2:64:53 RADIUS: starting accounting session 086A8B20E263C42D
Fri Apr 25 07:17:34 2025 daemon.info hostapd: wlan0: STA 3a:e2:09:b2:64:53 WPA: pairwise key handshake completed (RSN)
Fri Apr 25 07:17:34 2025 daemon.notice hostapd: EAPOL-4WAY-HS-COMPLETED 3a:e2:09:b2:64:53
Fri Apr 25 07:17:35 2025 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.140 3a:e2:09:b2:64:53
Fri Apr 25 07:17:35 2025 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.140 3a:e2:09:b2:64:53 OnePlus-11-5G
Hello Everyone
Any one facing same issue ? Any help is much appreciated. !!
Thanks
In the log I found that the AR300M is connected to the primary router (JioFiber-1504-4G) through repeater, and the Beacon loss has many reasons, and it may be interfered with by other 2.4G WiFi, the primary AP kicked out the AR300M since wireless resources is not enough, insufficient signal strength, etc.
You can manually downgrade to the previous version to see if this situation will reproduce again.
https://dl.gl-inet.com/
Hello Bruce,
Thanks for the response. Please share the steps to downgrade the version.
I am currently running Version - v4.3.25.
Thanks
Download firmware from GL.iNet download center, and upload to GL GUI > System > Upgrade.
Did you downgrade, and if so, did it help with beacon loss issues?
