Hi all,
I have a GL-AR300M-ext and some days ago automatically upgraded to 4.36 release but it lost some configurations.
So I had the bad idea to performed a factory reset and now I have 2.27 firmware
I tried to download last firmware to upgrade but without success⌠Web Interface says me that is a wrong hardware.
Please could you show me the correct procedure or give me, I think, an intermediate firmware I can install?
Also automatical upgrade is not working I think because is a too-old version
the only way to make it working is using openwrt-ar300m16-3.216-0321-1679391734.bin in Uboot that is for AR300M16, my model is GL-AR300M-ext I read that there is a NOR and a NAND memory, when I use Uboot I only can upload .bin files from AR300M16 model other files .img for AR300M Shadow (ext i think this is the correct) are not recognized ⌠also wifi SID is called: " GL-AR300M-c31-NOR" how can be sure to be booting fron NAND partition?
I upgraded U-boot to uboot-gl-ar300m-20220216-md5-97ff7bb80cbf129fa21f34ded1559ff8.bin to be able to upload new images and selecting NOR or NAND.
When I go to 192.168.1.1 I select the image and I go to âuploadâ I got immediatly âconnection resetâ and image is not uploaded.
If i go to 192.168.1.1/uboot.html i can flash and upgrade uboot correctly, but not firmware in main page after selecting them because of this connection reset.
