how do I configure a vlan on eth1?
simply by configuring under “physical interface” a custom interface, like “eth1.3” for participating in vlan number 3? On the switch port I have to define a tagged port for vlan 3, right?
Regards
Mikee
Regards
Mikee
For your information.
config interface 'lan'
option type 'bridge'
option ifname 'eth1.3'
option proto 'static'
option ip6assign '60'
option hostname 'GL-AR300M-ff3'
option ipaddr '192.168.9.1'
config interface 'wan'
option ifname 'eth0'
option proto 'dhcp'
config interface 'wan6'
option proto 'dhcpv6'
config switch
option name 'switch0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'switch0'
option vlan '3'
option ports '1 0t'
Thank you, kyson-lok!
Hello Kyson-lok,
no chance to get a tagged configuration running.
Running untagged configuration is (no switch configuration on gl-ar750):
switch (phy) ----- switch (gl-ar750) ------ switch (gl-ar750) ---------- switch (phy)
1 (untagged vlan 3) ----- wan eth0.3 ------- eth1 ---------- 1 (untagged vlan 4)
If I try to define tagged ports on the gl-ar750, no communication to lan and wan ports is possible, although using the vlan switch switches on gl-ar750, like you have shown before.
I am at reset count 60, I believe.
