Yeah. I found this description somewhere else.
I must say I really have no idea about what I am doing here…
So I found two files for the LITE version both *.bin.
Am I right I am dealing with NOR then?
I couldn’t connect to the IP. According to what I found this problem is specific to the damn LITE version.
More or less accidentally I found that when I connect to TTL and start the DHCP service it works and I can access the router from the browser for a short time. It was possible to start the upgrade as described but I don’t think it finished successfully.
Still no WiFi and neigher of the IPs accessible.
Should I have flashed the kernel.bin instead of sysupgrade.bin?
Spent nealy two days on it and could finally flash OEM-SW.
Seems totally random available.
Could find some oxidized patches around where the PCIE would go on the non-LITE.
I don’t know why it worked for a while back then, but now I tried to use it again after a long time: not accessible.
The LITE is not accessible in the recovery process.
Left LED on and the middle one indicating network traffic (WAN).
