Hi team,
I’m having some issues with my GL-AR300M. When booting with WAN cable plugged in, I cannot get IP address allocated via DHCP. I have to disconnect the cable and reconnect to get it to allocate IP address. I’ve tried upgrading to v4 just now but still same issue.
On the DHCP server side I can just see continuous DHCPDISCOVER
and DHCPOFFER
. I have also tried to SSH into the GL router and running udhcpc -i eth0
manually but also doesn’t work. Only workaround is to replug, but that’s annoying, is there any fix for this?
Thanks
