I am having an issue connecting to visible networks, I am able to connect to hidden networks of all kind but if the network is visible I am not able to.
Please help.
EDIT: I am not able to connect to networks that are visible and require a password. I am able to connect to visible open networks.
Pretty basic WPA2-PSK, but anything that requires a password and visible is failing. I am able to connect to open networks, and if I make a network hidden I can connect to it then.
What is also interesting is that if I associate with the network while hidden, I am able to associate to it when afterward hidden or visible.
If there is any other info you need, I am happy to provide it. I have tried getting into the console and associating to the wifi through wpa_cli, it just seems to time out over time. Other devices can connect to the wifi in question and I have confirmed that the password is correct.
You send me your ssid and key that you are trying to connect. You do not need to send exactly the same but should be very similar, e.g. same length, contains the same combination of characters.
I was trying everything, it looks like the issue is the wireless at work. For some reason it is unable to associate. I am able to hook up to everything else otherwise. Thanks again for your help. I probably need to look elsewhere to get this fixed.
