I have GL-AR300M router, i want run (both) VPN and TOR
When i run VPS and try run TOR i received error - WARNING: Conflicts!. All other VPN must be stopped
It’s possible run vpn and tor at the same time?
You cannot run Tor and VPN at the same time because the router does not know if it need to route the data via vpn or via Tor.
So you may need to run by ssh to the router and do everything manually. Let the UI set up one and you set up another manually.
could you write command for ssh please? example Tor in UI and vpn in ssh.
i want try the same but i am very new in all this.
I am afraid this is too complicated and I cannot write simple script for that.
Testing a script is quite a headache.
