GL-AR300M vs GL-AR150 performance difference
I don’t plan to use Wi-Fi on either of these routers, since I have a powerful Wi-Fi router already with me. It will just act as bridge between my WAN connection and Wi-Fi router, to do VPN.
Will there be any OpenVPN performance difference between the two routers when used in such a way ? or should i stick with GL-AR300M since it has more ram?
For OpenVPN,
AR150 max 8 Mbps
AR300M max 17 Mbps
For OpenVPN, Ethernet to Ethernet and Ethernet to WiFi:
AR150 max 8 Mbps
AR300M max 12 Mbps
Additional performance infos collected on follow links:
