There is an issue with the WAN port on this router - it doesn't recognize the connection of the gigabit cable. An important note: the gigabit cable going into the router comes from a PoE injector (from the port that doesn't supply power).
Here's what I have done so far:
The firmware was 4.3.11 - downgraded it to 4.3.7.
Through SSH, I set "speed 1000 duplex full autoneg on" for eth0 and eth1 (just in case, one of them should definitely be the WAN).
The MAC address is set to the one known by the provider.
Tried both my cable and the provided one with GL-AR300M16-ext - same result.
My gigabit cable works, as it is currently connected to an ASUS TUF-AX5400 and sometimes needs to be connected to another mini-router (a 10-year-old Chinese no-name) - everything is fine with them.
Connected the provided cable to the LAN of the ASUS TUF-AX5400 and to the WAN of the GL-AR300M16-ext - everything works, my router assigns an IP, and the GL-AR300M16-ext distributes the internet.
I have logs, but I didn't find anything useful there.
What am I missing? How can this be fixed?
Certainly. I don't expect the throughput to be 1000. I'm happy with 100. but the WAN port doesn't work with either a gigabit cable or the included 100.
I have connected the WAN port of my GL-AR300M16-ext with 4.3.11 default configuration to a Cisco SG200-08 gigabit switch. It auto negotiates and connects at 100 Mbit. The switch has one POE port and also non-POE ports. I am not home right now. I don't remember if I used a POE port on the switch, but I did not use a POE splitter and I think I plugged into a non-POE port.
I forgot an important point that radically changes the essence of the problem - after downgrading the firmware, the cable began to be recognized, but the address from the provider via DHCP is not assigned
The issue was resolved - I set static configurations for the WAN port. However, the final question "why the WAN is not receiving an address via DHCP from the ISP" remains relevant (although WAN port receives an IP address from other equipment) .
By the way, I tried different versions of the firmware and wrote to support about vlans - to no avail.
