I am having difficulty using RDP from one WiFi client in to another WiFi client. I have also noticed that I cannot ping from one client to another (These are windoze 10 clients).
Any suggestions appreciated.
Check the Windows firewall. RDP and Ping is disabled by default.
You are correct about ping, I will have to open that up, but RDP is open and works on my home Spectrum WiFi between clients so the GL-AR300M is having some effect.
OK I have it working, you were correct on both counts so cockpit error!!!!
Thanks for the support
