GL-AR300M16-ext repeater wifi wrong key or time out
This is the second location where i try to use this router, first at home, i have no problems, little router connects to my home wifi and then extends the coverage to a greater area. now i want to use it at my apartment complex gym, same way, i have the correct password (7pha8qnd5f?z is the password) but it doesn’t want to connect to after clicking JOIN, it spins for a while and then it’s either wrong key or time out. please help.
firmware is the latest stable one.
I am using Firmware 3.215 and connect to a wifi with this password and it works.
Can you give me the log after your connection failed? ssh to the router and use “logread” to get the log.
thank you for helping. but first, let me figure out how to SSH. i’d appreciate if you could send me in the right direction, please.
Please check docs about ssh SSH to the Router - GL.iNet Docs
