GL-AR300M16-Ext wifi not visible
Sometimes wifi just disappears and I have to reset it to get it working again, it has happened a couple of times. I wonder if someone else has experiences the same issue.
“reset” do you mean reboot?
In the wifi settings, can you set the channel to fixed channel?
Also check the power adapter you are using. Try a different one 5V2A.
