GL-AR300M16 no ssh access
I can’t ssh with root into my new GL-AR300M16 router. I tried to change the password, installed luci and added the ssh key, but the router still requires a password and I’m not able login. Installed the latest firmware 3.216 and tried reset router, but without success. Any ideas?
You want to login ssh without input a password, right?
I am not sure how you did. But I am using xshell in windows and it does this work easily, wihout need to change the router settings.
