I installiert the beweist Update, set the Ports 1194 and 443 to open and tested with several VPN Provider: I downloaded the OpenVPN configuration file, uploaded ist into the router and tried to connect. But everytime the same, the auth failed. AND: NO ! I used the correct credentials! It seems the router has a problem with the TLS Web authentication. Has someone a Test configuration that should work? Or a hint what to check else?
Best regards
Lippikus
