Hi all, i wanted to check to see if the config that i would like to run is possible. I want to connect the WAN port to my current internet provider and then use the AR750 as a backup in case the ISP on the WAN side either goes down or is not for some reason available. Is that doable out of the box?
So was just trying to confirm if i can use a ATT or a T-Mobile SIM in this device. If this is not the case than thats OK, I will save my money and look for another product.
