Hello, i have a GL-AR750 (FW 3.211). I use it for a helium miner (sensecap) und OpenVPN.
GL-AR750 is connected by wifi to the internet router. The miner is connected by LAN to the GL.
I have the problem, that the system works stable only few days. Then the GL losing WLAN connection.
If I reconnect it to to internet router it works a few hours, then losing the connection again. After powering off, it is stable 2-3 days.
Automatic reconnect to wifi is on.
The distance from internet router to GL-AR750 is only 2 meters.
The internet router is a VODAFONE Station, but also tested with Fritzbox router.
I also use 30pcs of mango routers, all stable, same configurations.
Does the GL-AR750 has a logfile? How can i get this?
Log in via SSH using PuTTY freeware or equivalent, with root password same as admin password.
Run command “logread” for System Log and “dmesg” for Kernel Log.
Log into LuCI and go to Status → System Log and Status → Kernel Log.
