On your Samsung S20, when you go to Settings → Connections → Wi-Fi, what is the SSID of the GL-AR750 Creta? Try clicking on the SSID settings “gear symbol” , then clicking on “Manage router” if it exists. That should open the browser at the IP address of the Creta.
a) with my Samsung S2 via Wlan
b) not with Samsung ST8250 in the same WLAN
c) not per SSH (putty) in the same LAN
d) not per Browser Edge or Chrome in Windows PC in the same LAN
The “only” problem is, that he ist not administrable per Web-Browser or SSH.
Hi is connected via WAN Port to my Fritzbox6591. He has get via DHCP the IPs 192.168.9.17 and .217 (WLAN)
I know, that 192.168.9.x is the Standard Guest-Net of the AR750. But I can’t change my LAN adress.
In the AR750 Guest-Net ist set to 192.168.117.x
I see him on the Smarthone as WLAN GL-AR750-110-5G und get the IP 192.168.8.110 . But in the Browser I cannot reach him under 192.168.8.1
why??
update:
I reach him under 192.168.8.1 on my Tablet .
The admin-password is the old !
I connect him via WAN-port to my Fritzbox
sucessful hi gets the lokap IP 192.168.9.16
Under "Aktualisierung I see “aktuelle Version 3.211” and
“letzte Aktualisierung unavailable”
