I would like to set up my AR750 S to connect to my MOFI 4500 cellular router using ethernet cables. I read about LAN to WAN and LAN to LAN. I tried LAN to LAN but the AR750 doesn’t see an internet connection when I do this. I started to try LAN to WAN but could not see how to manually change the WAN address on the 750.
I tried turning on Access Point but then VPN options aren’t available.
What I would Like to achieve is:
- Most of the time have my Mac Mini Connect through Ethernet to the MOFI so my mini’s SMB can connect to my Apple TV
- But when I need VPN connect to the 750 using WIFI and VPN running full time
- Other Tablets and Computers could also connect to the 750 using wifi if requiring VPN and directly to the MOFI when wanting higher internet speed.
By the way I run my Mac Mini headless, and unfortunately VPN’s can not be turned on on either the Mini or my iPad when controlling the Mini from my iPad. Otherwise I would just activate VPN’s on the individual devices.
Any help would be appreciated.
