I think I’ve seen people here with the same problem but I have not see a solution .
I am using the AR-750S as a VPN router
I have an incoming Internet cable from my network connected to the AR-750S
I am then sharing the AR750S with WiFi
When I connect to the AR750S WIFI, everything works well, I have access to the Internet and I can access all the local hosts on the LAN (192.168.0.0/24)
As soon as I activate VPN CLient on the AR750S everything goes as expected connecting to the internet
I connect to the AR750S WIFI and I surf the internet via VPN no problems
But as soon as I try to ping or ssh a machine on the LAN, I cannot connect.
I think the routing is correct but something is blocking all outgoing ports to the LAN, could this be a setting I’ve missed ?
ping 192.168.0.21
PING 192.168.0.21 (192.168.0.21) 56(84) bytes of data.
From 192.168.8.1 icmp_seq=1 Destination Port Unreachable
traceroute 192.168.0.21
traceroute to 192.168.0.21 (192.168.0.21), 30 hops max, 60 byte packets
1 console.gl-inet.com (192.168.8.1) 2.443 ms 2.651 ms 4.435 ms
2 console.gl-inet.com (192.168.8.1) 4.430 ms 4.421 ms 4.412 ms
ip route list
default via 192.168.8.1 dev wlp6s0 proto dhcp metric 600
169.254.0.0/16 dev wlp6s0 scope link metric 1000
192.168.8.0/24 dev wlp6s0 proto kernel scope link src 192.168.8.197 metric 600
Can someone please help me. I’m obviously missing a step or doing something wrong in the setup.
Thanks in advance.
