gesman
For some reason I lost ability to connect to internet with this router. Latest firmware.
Under “Internet” settings it is successfully connected to active AP.
But when i connect to it’s own hotspot - there is no internet connection.
It used to work before. I tried reboot/restart - no avail.
Anything i could check?
alzhao
2
can you show a screenshot of the internet page?
alzhao
4
Thanks for the screenshot. The screenshot itself does not say any problem.
In order to check, you can ssh to the router and try to check if the router has Internet itself.
ping 8.8.8.8
did you ever config anything else? e.g. vpn, vpn policies, dns via tls etc?
Simply you can go to more settings → revert firmware and reset the router and start over and see.
