Is there a way to make it when you go to the Ip of the router it isn’t the login screen?
Like can I hide it some where else and just set the ip to be a different HTML page like showing guest how to log in or somthing?
If people are connecting to your guest wifi (standard 192.168.9.1) then you can force them to a captive portal screen.
