I updated the firmware to 3.105 to get the advanced configuring options for OpenVPN. I was able to follow the steps and configure according to the link above in the ‘Luci’ interface. However when I go to start the OpenVPN Cloud instance, it does not start or connect.
Are their any extra setting required for the GL-AR750S? One of the requirements is openvpn-polarssl package, which is not present. Can that be an issue ?
Thanks a lot for you help. It seems to be working. I had tried with the older version firmware (3.104) and it was not working so I did not try it with the 3.105 firmware version. But it works. YAY !!!
