Had a look about the forum, but couldn’t see a solution for this.
GL-AR750S is in Repeater mode, repeating a open wifi network (captive portal that requires un and pw where I have a bash script running fine to do).
It just seems to drop our every few hours with the following error recorded in the log:
Mon Apr 26 14:58:22 2021 kern.warn kernel: [106756.588617] ------------[ cut here ]------------
Mon Apr 26 14:58:22 2021 kern.warn kernel: [106756.593644] WARNING: CPU: 0 PID: 0 at backports-4.19.161-1/net/mac80211/tx.c:946 ieee80211_proberesp_get+0x30c/0xf88 [mac80211]
Mon Apr 26 14:58:22 2021 kern.warn kernel: [106756.605618] Modules linked in: fast_classifier ath9k ath9k_common rt2800usb rt2800lib pppoe ppp_async option ath9k_hw ath10k_pci ath10k_core ath usb_wwan sierra_net sierra rt2x00usb rt2x00lib rndis_host qmi_wwan pppox ppp_mppe ppp_generic nf_nat_pptp nf_conntrack_pptp mac80211 iptable_nat ipt_REJECT ipt_MASQUERADE huawei_cdc_ncm ebtable_nat ebtable_filter ebtable_broute cp210x cfg80211 cdc_ncm cdc_ether xt_time xt_tcpudp xt_tcpmss xt_statistic xt_state xt_recent xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_hl xt_helper xt_hashlimit xt_ecn xt_dscp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_TCPMSS xt_REDIRECT xt_LOG xt_IPMARK xt_HL xt_FLOWOFFLOAD xt_DSCP xt_CT xt_CLASSIFY wireguard usbserial usbnet ts_fsm ts_bm slhc nf_reject_ipv4 nf_nat_tftp nf_nat_snmp_basic nf_nat_sip
Mon Apr 26 14:58:22 2021 kern.warn kernel: [106756.679246] nf_nat_redirect nf_nat_proto_gre nf_nat_masquerade_ipv4 nf_nat_irc nf_conntrack_ipv4 nf_nat_ipv4 nf_nat_h323 nf_nat_ftp nf_nat_amanda nf_log_ipv4 nf_flow_table_hw nf_flow_table nf_defrag_ipv4 nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sip nf_conntrack_rtcache nf_conntrack_proto_gre nf_conntrack_netlink nf_conntrack_irc nf_conntrack_h323 nf_conntrack_ftp nf_conntrack_broadcast ts_kmp nf_conntrack_amanda iptable_raw iptable_mangle iptable_filter ipt_ECN ipheth ip_tables ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among ebt_802_3 crc_ccitt compat_xtables compat cdc_wdm cdc_acm xt_u32 fuse sch_teql sch_sfq sch_red sch_prio sch_pie sch_multiq sch_gred sch_fq sch_dsmark sch_codel sch_cbq em_text em_nbyte em_meta em_cmp act_simple act_police act_pedit
Mon Apr 26 14:58:22 2021 kern.warn kernel: [106756.752920] act_ipt act_gact act_csum libcrc32c act_connmark sch_tbf sch_ingress sch_htb sch_hfsc em_u32 cls_u32 cls_tcindex cls_route cls_matchall cls_fw cls_flow cls_basic act_skbedit act_mirred xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_nat nf_conntrack_ipv6 nf_defrag_ipv6 nf_nat_ipv6 ip6t_NPT ip6t_MASQUERADE nf_nat_masquerade_ipv6 nf_nat nf_conntrack nf_log_ipv6 nf_log_common ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 ip6_udp_tunnel udp_tunnel tun vfat fat ntfs nls_utf8 nls_iso8859_1 nls_cp437
Mon Apr 26 14:58:22 2021 kern.warn kernel: [106756.826403] shortcut_fe sha1_generic ecb uas usb_storage uhci_hcd ohci_platform ohci_hcd ehci_platform sd_mod scsi_mod ehci_hcd gpio_button_hotplug ext4 mbcache jbd2 exfat phy_ar7200_usb phy_ar7100_usb usbcore nls_base usb_common mii aead crypto_null cryptomgr crc32c_generic crypto_hash
Mon Apr 26 14:58:22 2021 kern.warn kernel: [106756.852852] CPU: 0 PID: 0 Comm: swapper Tainted: G W 4.14.221 #0
Mon Apr 26 14:58:22 2021 kern.warn kernel: [106756.860316] Stack : 805d0000 80588b18 00000000 00000000 80555c0c 87c07aec 805b5e0c 805b5a27
Mon Apr 26 14:58:22 2021 kern.warn kernel: [106756.869059] 80551cf0 00000000 80713670 000003b2 0000001a 00000001 87c07aa0 214d6847
Mon Apr 26 14:58:22 2021 kern.warn kernel: [106756.877794] 00000000 00000000 80710000 000029c8 00000000 00000000 00000008 00000000
Mon Apr 26 14:58:22 2021 kern.warn kernel: [106756.886529] 000010f0 46207210 000010ef 2020342e 00000000 00000009 00000000 86467a04
Mon Apr 26 14:58:22 2021 kern.warn kernel: [106756.895254] 8642f1a4 000003b2 0000001a 866b0184 00000001 802cbcb4 00000000 80710000
Mon Apr 26 14:58:22 2021 kern.warn kernel: [106756.903993] …
Mon Apr 26 14:58:22 2021 kern.warn kernel: [106756.906616] Call Trace:
Mon Apr 26 14:58:22 2021 kern.warn kernel: [106756.909247] [<8006aaac>] show_stack+0x58/0x100
Mon Apr 26 14:58:22 2021 kern.warn kernel: [106756.913943] [<800853b0>] __warn+0xe4/0x13c
Mon Apr 26 14:58:22 2021 kern.warn kernel: [106756.918278] [<80085498>] warn_slowpath_null+0x1c/0x34
Mon Apr 26 14:58:22 2021 kern.warn kernel: [106756.923711] [<8642f1a4>] ieee80211_proberesp_get+0x30c/0xf88 [mac80211]
Mon Apr 26 14:58:22 2021 kern.warn kernel: [106756.930699] —[ end trace a8570a6fd9fb0ec7 ]—
And just before all that it logs as:
Mon Apr 26 14:58:10 2021 kern.warn kernel: [106746.055978] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
Mon Apr 26 14:58:10 2021 kern.warn kernel: [106746.063673] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
Mon Apr 26 14:58:10 2021 kern.warn kernel: [106746.071435] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
Mon Apr 26 14:58:10 2021 kern.warn kernel: [106746.079185] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
Mon Apr 26 14:58:10 2021 kern.warn kernel: [106746.086936] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
Mon Apr 26 14:58:10 2021 kern.warn kernel: [106746.094646] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
Mon Apr 26 14:58:10 2021 kern.warn kernel: [106746.102391] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
Mon Apr 26 14:58:10 2021 daemon.notice wpa_supplicant[1562]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Mon Apr 26 14:58:11 2021 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED e4:b3:18:95:ce:14
Mon Apr 26 14:58:11 2021 daemon.info hostapd: wlan1: STA e4:b3:18:95:ce:14 IEEE 802.11: authenticated
Mon Apr 26 14:58:11 2021 daemon.info hostapd: wlan1: STA e4:b3:18:95:ce:14 IEEE 802.11: associated (aid 1)
Mon Apr 26 14:58:11 2021 daemon.notice hostapd: wlan1: AP-STA-CONNECTED e4:b3:18:95:ce:14
Mon Apr 26 14:58:11 2021 daemon.info hostapd: wlan1: STA e4:b3:18:95:ce:14 RADIUS: starting accounting session B615C665110B2571
Mon Apr 26 14:58:11 2021 daemon.info hostapd: wlan1: STA e4:b3:18:95:ce:14 WPA: pairwise key handshake completed (RSN)
Mon Apr 26 14:58:11 2021 daemon.info dnsmasq-dhcp[3244]: DHCPREQUEST(br-lan) 192.168.8.170 e4:b3:18:95:ce:14
Mon Apr 26 14:58:11 2021 daemon.info dnsmasq-dhcp[3244]: DHCPACK(br-lan) 192.168.8.170 e4:b3:18:95:ce:14 DESKTOP-C4TMNPR
