GL-AR750S-Ext Failover - Starlink & Cellular
Hi there. We are using our GL-AR750S-Ext with SpaceX Starlink Satellite Internet (repeater) and a tethered iPhone on Verizon. Does this combination, set up this way, allow for failover if one method loses signal temporarily? Also, would a card reader with our mobile hot spot’s SIM card plugged into the USB port on the GL-AR750S-Ext work instead of needing the iPhone tethered? Thank you.
As I understand, you have two connections:
  • Repeater to Starlink
  • USB tethering to iPhone
With this setup, the router will do failover. I.e. It will use repeater first then fail over to USB tethering.
