I have had my GL-AR750S-EXT for a few years and never used it much.
Now, I am trying to use it, but not having much success.
The unit powers on. The power LED is lit, but neither the 2G nor the 5G LED are lit. So, of course, it is not available for a WiFi connection.
When I reset, it does not change this; WiFi is still off. It is possible that when playing around with it when I first got it, that I turned WiFi off in the control panel, but wouldn't reset turn it back on?
Anyway, when I plug it into my laptop with an ethernet cable (and a Belkin USB C to ethernet adapter), it shows up as a network.., but always says "no internet, identifying". It's not connected to the internet, so I am not worried about that.
When I try to go to 198.168.8.1 i can never connect and get the control panel. It just times out.
Once , briefly, I saw that it stopped saying "identifying" and identified the model of the router.
the thing was sitting for a few minutes, and then when i looked in my networks, the model number was identified for the ethernet connection.., and.., both wifi networks were visible.
Something went wrong during updateProbably you have chosen wrong file (too big or too small) or you were trying to update ART on device with unknown FLASH type (and size) which is not allowed. Please, try again or contact with the author of this modification. You can also get more information during update in U-Boot console.
It's interesting that i can connect to that 192.168.1.1 UBoot web UI.., and bring up the page that asks me to look for the downloaded file, and can then star the upgrade...
Old AR750S Uboot code will not load anything newer than 3.104 firmware. Unfortunately, GL iNet has removed the 3.104 firmware from their firmware page. Why, I don't know, but at least one user was able to get support to send them the 3.104 img firmware file that worked with their old version of Uboot code. After loading the 3.104 img firmware file, they were able load 3.105->3.216->4.x using the .tar file and the GL iNet GUI.
It is nice to know the reason for removing the 3.104 firmware. Those of us with older ar750s units are kind of in a bind, as the update procedure for Uboot does not always work, as the old version of Uboot is very temperamental. Without the new Uboot code installed on an older ar750s, and without the 3.104 firmware, we are stuck without a way to un-brick our routers.
Hopefully you can help @jgf310 save his router, and keep it out of a landfill.
I have used Uboot and the 3.104 img file to get my ar750s running on 3.104, then used the .tar file and the GUI interface on 3.104 to upgrade to 3.105 with the 3.105.tar file, and then used 3.105 with its GUI and the 3.2x.tar file to upgrade to 3.2x. Multi-step, but I got there.
