AR750s > (via wireless/repeater mode) Telco router > internet
Whenever the telco router is powered off and powered back on without shutting down the AR750s before, the AR750s dies. It will not connect (ever, even after a reboot) to the Telco router until I do a full factory reset.
Version: 3.203 but the same thing was happening with 3.201. I do not remember about 3.104.
Any suggestion on how to reconnect to the telco router?
Bad wording on my part (sorry but english is not my first nor second language). It will not connect to the telco router.
internet > scan > select my telco router and enter the password. It will not connect. I’ve tried other others (from the neighbours) and still no connection. I have to reset to the factory defaults, reenter all my data (port forwarding, mac static ips…, only 10 minutes,) and then I’m good to go.
Here is a section (there are 450+ lines identical)
>>>TOP line 1 of logread<<<
Wed Aug 25 22:22:00 2021 daemon.err stubby[1976]: Could not schedule query: None of the configured upstreams could be used to send queries on the specified transports
Wed Aug 25 22:22:10 2021 daemon.err stubby[1976]: Could not schedule query: None of the configured upstreams could be used to send queries on the specified transports
Wed Aug 25 22:22:52 2021 kern.info kernel: [14641.410555] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:22:53 2021 kern.warn kernel: [14642.905127] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Wed Aug 25 22:22:53 2021 kern.info kernel: [14642.921204] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:23:44 2021 kern.info kernel: [14693.575767] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:23:45 2021 kern.warn kernel: [14695.050166] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Wed Aug 25 22:23:45 2021 kern.info kernel: [14695.066523] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:24:36 2021 kern.info kernel: [14745.755492] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:24:37 2021 kern.warn kernel: [14747.238765] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Wed Aug 25 22:24:37 2021 kern.info kernel: [14747.254874] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:25:28 2021 kern.info kernel: [14797.916214] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:25:30 2021 kern.warn kernel: [14799.444565] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Wed Aug 25 22:25:30 2021 kern.info kernel: [14799.460654] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:26:20 2021 kern.info kernel: [14850.115590] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:26:22 2021 kern.warn kernel: [14851.584874] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Wed Aug 25 22:26:22 2021 kern.info kernel: [14851.600914] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:26:25 2021 daemon.err stubby[1976]: Could not schedule query: None of the configured upstreams could be used to send queries on the specified transports
Wed Aug 25 22:26:42 2021 daemon.err stubby[1976]: Could not schedule query: None of the configured upstreams could be used to send queries on the specified transports
Wed Aug 25 22:27:12 2021 kern.info kernel: [14902.249923] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:27:14 2021 kern.warn kernel: [14903.737924] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Wed Aug 25 22:27:14 2021 kern.info kernel: [14903.754102] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:28:05 2021 kern.info kernel: [14954.436009] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:28:06 2021 kern.warn kernel: [14955.925421] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Wed Aug 25 22:28:06 2021 kern.info kernel: [14955.941716] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:28:57 2021 kern.info kernel: [15006.605973] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:28:58 2021 kern.warn kernel: [15008.092692] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Wed Aug 25 22:28:58 2021 kern.info kernel: [15008.108879] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:29:49 2021 kern.info kernel: [15058.740555] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:29:50 2021 kern.warn kernel: [15060.217991] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Wed Aug 25 22:29:50 2021 kern.info kernel: [15060.234153] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:30:41 2021 kern.info kernel: [15110.883318] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:30:43 2021 kern.warn kernel: [15112.362744] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Wed Aug 25 22:30:43 2021 kern.info kernel: [15112.378840] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:30:58 2021 daemon.err stubby[1976]: Could not schedule query: None of the configured upstreams could be used to send queries on the specified transports
Wed Aug 25 22:31:16 2021 daemon.err stubby[1976]: Could not schedule query: None of the configured upstreams could be used to send queries on the specified transports
Wed Aug 25 22:31:33 2021 kern.info kernel: [15163.070983] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:31:35 2021 kern.warn kernel: [15164.571189] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Wed Aug 25 22:31:35 2021 kern.info kernel: [15164.587501] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:32:25 2021 kern.info kernel: [15215.224707] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:32:27 2021 kern.warn kernel: [15216.708706] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Wed Aug 25 22:32:27 2021 kern.info kernel: [15216.724794] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:33:18 2021 kern.info kernel: [15267.389908] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:33:19 2021 kern.warn kernel: [15268.874586] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Wed Aug 25 22:33:19 2021 kern.info kernel: [15268.890689] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:34:10 2021 kern.info kernel: [15319.546512] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:34:11 2021 kern.warn kernel: [15321.053363] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Wed Aug 25 22:34:11 2021 kern.info kernel: [15321.069591] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:35:02 2021 kern.info kernel: [15371.752506] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:35:03 2021 kern.warn kernel: [15373.243833] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Wed Aug 25 22:35:03 2021 kern.info kernel: [15373.259960] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:35:11 2021 daemon.info dnsmasq-dhcp[2669]: DHCPDISCOVER(br-lan) 192.168.8.113 00:24:32:50:06:15
Wed Aug 25 22:35:11 2021 daemon.info dnsmasq-dhcp[2669]: DHCPOFFER(br-lan) 192.168.8.113 00:24:32:50:06:15
Wed Aug 25 22:35:13 2021 daemon.info dnsmasq-dhcp[2669]: DHCPREQUEST(br-lan) 192.168.8.113 00:24:32:50:06:15
Wed Aug 25 22:35:13 2021 daemon.info dnsmasq-dhcp[2669]: DHCPACK(br-lan) 192.168.8.113 00:24:32:50:06:15 newt
Wed Aug 25 22:35:23 2021 daemon.err stubby[1976]: Could not schedule query: None of the configured upstreams could be used to send queries on the specified transports
Wed Aug 25 22:35:48 2021 daemon.err stubby[1976]: Could not schedule query: None of the configured upstreams could be used to send queries on the specified transports
Wed Aug 25 22:35:54 2021 kern.info kernel: [15423.916880] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:35:56 2021 kern.warn kernel: [15425.378172] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Wed Aug 25 22:35:56 2021 kern.info kernel: [15425.394212] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:36:04 2021 daemon.err stubby[1976]: Could not schedule query: None of the configured upstreams could be used to send queries on the specified transports
Wed Aug 25 22:36:17 2021 daemon.err stubby[1976]: Could not schedule query: None of the configured upstreams could be used to send queries on the specified transports
Wed Aug 25 22:36:25 2021 authpriv.info dropbear[10742]: Child connection from 192.168.8.113:43252
Wed Aug 25 22:36:30 2021 authpriv.notice dropbear[10742]: Password auth succeeded for 'root' from 192.168.8.113:43252
Wed Aug 25 22:36:46 2021 kern.info kernel: [15476.055391] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:36:48 2021 kern.warn kernel: [15477.494237] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Wed Aug 25 22:36:48 2021 kern.info kernel: [15477.510341] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:37:21 2021 daemon.err stubby[1976]: Could not schedule query: None of the configured upstreams could be used to send queries on the specified transports
Wed Aug 25 22:37:38 2021 kern.info kernel: [15528.205974] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Wed Aug 25 22:37:40 2021 kern.warn kernel: [15529.637388] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Wed Aug 25 22:37:40 2021 kern.info kernel: [15529.653554] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
root@GL-AR750S:~#
I had to trim some of log it was too big for the board.
Please note that the ipv6 is disabled on the ar750s-ext and on the telco router.
Did you turn on DNS via TLS cloudflare or nextdns? Can you turn that off?
Seems stubby send a lot of logs after turning off main wifi. I tried the same. When turn off dns encryption, the router quickly recover and wifi is out.
DNS Rebinding Attack Protection: ON
Override DNS Settings for All Clients: ON
DNS over TLS (Cloudflare or NextDNS): ON
Select DNS Server: Cloudflare
Dnscrypt-Proxy Settings : disabled
Manual DNS Server Settings: disabled
new settings
Override DNS Settings for All Clients: OFF
DNS over TLS (Cloudflare or NextDNS): OFF
Dnscrypt-Proxy Settings: disabled
Specs-wise, the dual-band GL.iNet Slate supports wireless speed of up to 300 Mbps over 2.4 GHz and 433 Mbps over 5 GHz, and comes with three Gigabit Ethernet ports. It has a USB 2.0 port for connecting a 3G/4G USB modem, and a microSD card slot with max.
Note the date and time. I didn’t set it up yet. The 1st task that I did was to try to connect to the telco router and since it wasn’t, I ssh-ed in to the ar750s and did a logread. The full it too big to paste, but if you need I have a copy that I can email.
I noticed that the router seemed to be working on the wrong channel
Did you change the router’s country code?
Or you can try setting the Telco Router as a fixed channel.
