We have a GL-AR750S-EXT Slate set up in our 5th wheel using Visible wireless on an Iphone 6S.
When tethered to the Iphone the internet connection is constantly lost every few minutes or so, makes no difference if tethered or is using wifi to connect to the Slate. I have tried all the obvious things like bigger PSU (3A) cooling with a fan. This is part of the log.
Wed Jul 20 16:08:31 2022 user.info mwan3rtmon[2896]: Detect rtchange event.
Wed Jul 20 16:08:32 2022 user.notice firewall: Reloading firewall due to ifup of tethering (eth1)
Wed Jul 20 16:09:55 2022 user.info mwan3rtmon[2896]: Detect rtchange event.
Wed Jul 20 16:09:55 2022 user.notice firewall: Reloading firewall due to ifup of tethering (eth1)
Wed Jul 20 16:14:12 2022 user.info mwan3rtmon[2896]: Detect rtchange event.
Wed Jul 20 16:14:13 2022 user.notice firewall: Reloading firewall due to ifup of tethering (eth1)
Wed Jul 20 16:21:34 2022 user.info mwan3rtmon[2896]: Detect rtchange event.
Wed Jul 20 16:21:35 2022 user.notice firewall: Reloading firewall due to ifup of tethering (eth1)
Everytime this happens it disconnects from the internet.
The only connection setup that works is to tether the phone to a win10 laptop then connect with wifi hotspot to the slate. I get a very similar log except if never disconnects from the internet and has been rock solid for 12 hours plus. Here is part of that log.
Wed Jul 20 04:33:46 2022 user.info mwan3rtmon[2896]: Detect rtchange event.
Wed Jul 20 04:33:47 2022 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Wed Jul 20 04:39:46 2022 user.info mwan3rtmon[2896]: Detect rtchange event.
Wed Jul 20 04:39:47 2022 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Wed Jul 20 04:45:52 2022 user.info mwan3rtmon[2896]: Detect rtchange event.
Wed Jul 20 04:45:53 2022 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Wed Jul 20 04:51:53 2022 user.info mwan3rtmon[2896]: Detect rtchange event.
Wed Jul 20 04:51:54 2022 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Wed Jul 20 04:57:51 2022 user.info mwan3rtmon[2896]: Detect rtchange event.
Wed Jul 20 04:57:52 2022 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Wed Jul 20 05:00:54 2022 user.info mwan3rtmon[2896]: Detect rtchange event.
Wed Jul 20 05:00:55 2022 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Wed Jul 20 05:03:59 2022 user.info mwan3rtmon[2896]: Detect rtchange event.
Wed Jul 20 05:04:00 2022 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
This works but is very cumbersome, I would like to be able to have the same rock solid internet connection with the Iphone tethered to the Slate. Is there some set parameters that I may have incorrect?
Thanks!!
alzhao
July 21, 2022, 10:48am
2
Does your Visible network permet ping?
Seems that it disable ping and the router cannot detect Internet.
You can also try to disable mwan3 so that the router do not use ping to detect Internet.
hi,
i have the ar750s-ext, visible and a google pixel 4a
never had an issue with usb tethering.
Yes Visible does allow ping, however the latency can be very high, when I tested the ping in diagnostics it failed 9 out of 10 times and when it was successful the latency was 200ms!
I will try to disable mwan3 and see if that helps.
I think android deals with tethering better than ios, what does your log look like?
never needed to look at the log.
let me know how to access the log and i will take a look at it.
I disabled mwan3 in startup, This works well< however after some hours can be as many as 12 and as few as 2 I get this back again and need to manually stop mwan3 again??
Sat Jul 23 21:34:32 2022 user.info mwan3rtmon[2592]: Detect rtchange event.
Sat Jul 23 21:34:32 2022 user.notice firewall: Reloading firewall due to ifup of tethering (eth1)
Try also disabling gl_monitor in Startup because it can also start mwan3.
I tried disabling gl_monitor and rebooting, everything is fine for a few hours then i get the mwan3 event again and a reloading of the firewall. it seems that the only way to prevent this for any length of time is to stop the mwan3 process in the startup menu. This is OK but not a permanent solution. Does anyone have any other ideas?
You can uninstall the mwan3 package.
Since this is a feature that I never use on my travel routers, and it sends out large numbers of ping packets, which is something I really do not want my routers doing, I always just remove it using ssh and the command:
opkg remove mwan3
If you look through past posts in this forum, you will find multiple people have complained for various reasons that mwan3 should have a setting in the main GL iNet GUI to turn it on/off and it should be off by default.
Hi, I just got my new ATX1800, and my current place does not have wifi, so Im connecting my iphone to the router via the tethering mode. However, Im having the same issue where every now and then, the router disconnects from the iphone.
I am trying to uninstall mwan3 (gl-sdk4-mwan3), but it keeps failing.
Sincerely a new user
This is what I did, worked perfectly, solved all my problems! router has been up with tethered iphone for months now.
Hi again, it’s seemingly still happening. I’ll post the logs (with comments on notable logs):
ue Apr 11 09:32:01 2023 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED bc:ce:25:25:4f:62 0 0
Tue Apr 11 09:32:01 2023 daemon.info hostapd: wlan1: STA bc:ce:25:25:4f:62 IEEE 802.11: disassociated
Tue Apr 11 09:32:02 2023 daemon.info hostapd: wlan1: STA bc:ce:25:25:4f:62 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Tue Apr 11 09:35:04 2023 daemon.info hostapd: wlan1: STA bc:ce:25:25:4f:62 IEEE 802.11: authenticated
Tue Apr 11 09:35:04 2023 daemon.info hostapd: wlan1: STA bc:ce:25:25:4f:62 IEEE 802.11: associated (aid 3)
Tue Apr 11 09:35:04 2023 daemon.notice hostapd: wlan1: AP-STA-CONNECTED bc:ce:25:25:4f:62 0 0
Tue Apr 11 09:35:04 2023 daemon.info hostapd: wlan1: STA bc:ce:25:25:4f:62 RADIUS: starting accounting session 4C9417D440D06453
Tue Apr 11 09:35:04 2023 daemon.info hostapd: wlan1: STA bc:ce:25:25:4f:62 WPA: pairwise key handshake completed (RSN)
Tue Apr 11 09:35:04 2023 daemon.notice hostapd: wlan1: STA-OPMODE-SMPS-MODE-CHANGED bc:ce:25:25:4f:62 static
Tue Apr 11 09:35:05 2023 daemon.info dnsmasq-dhcp[4480]: DHCPDISCOVER(br-lan) bc:ce:25:25:4f:62
Tue Apr 11 09:35:05 2023 daemon.info dnsmasq-dhcp[4480]: DHCPOFFER(br-lan) 192.168.8.187 bc:ce:25:25:4f:62
Tue Apr 11 09:35:05 2023 daemon.info dnsmasq-dhcp[4480]: DHCPREQUEST(br-lan) 192.168.8.187 bc:ce:25:25:4f:62
Tue Apr 11 09:35:05 2023 daemon.info dnsmasq-dhcp[4480]: DHCPACK(br-lan) 192.168.8.187 bc:ce:25:25:4f:62
Tue Apr 11 09:35:13 2023 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED bc:ce:25:25:4f:62 0 0
Tue Apr 11 09:35:13 2023 daemon.info hostapd: wlan1: STA bc:ce:25:25:4f:62 IEEE 802.11: disassociated
Tue Apr 11 09:35:14 2023 daemon.info hostapd: wlan1: STA bc:ce:25:25:4f:62 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Tue Apr 11 09:35:18 2023 daemon.info hostapd: wlan1: STA bc:ce:25:25:4f:62 IEEE 802.11: authenticated
Tue Apr 11 09:35:18 2023 daemon.info hostapd: wlan1: STA bc:ce:25:25:4f:62 IEEE 802.11: associated (aid 3)
Tue Apr 11 09:35:18 2023 daemon.notice hostapd: wlan1: AP-STA-CONNECTED bc:ce:25:25:4f:62 0 0
Tue Apr 11 09:35:18 2023 daemon.info hostapd: wlan1: STA bc:ce:25:25:4f:62 RADIUS: starting accounting session CE4746C605273A0F
Tue Apr 11 09:35:18 2023 daemon.info hostapd: wlan1: STA bc:ce:25:25:4f:62 WPA: pairwise key handshake completed (RSN)
Tue Apr 11 09:35:18 2023 daemon.notice hostapd: wlan1: STA-OPMODE-SMPS-MODE-CHANGED bc:ce:25:25:4f:62 static
Tue Apr 11 09:35:18 2023 daemon.info dnsmasq-dhcp[4480]: DHCPDISCOVER(br-lan) bc:ce:25:25:4f:62
Tue Apr 11 09:35:18 2023 daemon.info dnsmasq-dhcp[4480]: DHCPOFFER(br-lan) 192.168.8.187 bc:ce:25:25:4f:62
Tue Apr 11 09:35:18 2023 daemon.info dnsmasq-dhcp[4480]: DHCPREQUEST(br-lan) 192.168.8.187 bc:ce:25:25:4f:62
Tue Apr 11 09:35:18 2023 daemon.info dnsmasq-dhcp[4480]: DHCPACK(br-lan) 192.168.8.187 bc:ce:25:25:4f:62
Tue Apr 11 09:35:26 2023 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED bc:ce:25:25:4f:62 0 0
Tue Apr 11 09:35:26 2023 daemon.info hostapd: wlan1: STA bc:ce:25:25:4f:62 IEEE 802.11: disassociated
Tue Apr 11 09:35:27 2023 daemon.info hostapd: wlan1: STA bc:ce:25:25:4f:62 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Tue Apr 11 10:25:13 2023 daemon.notice hostapd: wlan1: AP-STA-POLL-OK 7a:66:ef:f4:06:d4
Tue Apr 11 10:29:58 2023 kern.info kernel: [30268.775436] usb 1-1: USB disconnect, device number 2
Tue Apr 11 10:29:58 2023 daemon.notice netifd: Network device 'eth3' link is down
// internet loss :(
Tue Apr 11 10:29:58 2023 daemon.notice netifd: Interface 'tethering' has link connectivity loss
Tue Apr 11 10:29:58 2023 daemon.info avahi-daemon[3719]: Interface eth3.IPv4 no longer relevant for mDNS.
Tue Apr 11 10:29:58 2023 daemon.info avahi-daemon[3719]: Leaving mDNS multicast group on interface eth3.IPv4 with address 172.20.10.2.
Tue Apr 11 10:29:58 2023 daemon.err usbmuxd[7387]: [10:29:58.339][3] Removed device 1 on location 0x10002
Tue Apr 11 10:29:58 2023 daemon.info avahi-daemon[3719]: Withdrawing address record for 172.20.10.2 on eth3.
Tue Apr 11 10:29:58 2023 daemon.notice netifd: tethering (7995): udhcpc: SIOCGIFINDEX: No such device
Tue Apr 11 10:29:58 2023 daemon.notice netifd: tethering (7995): udhcpc: received SIGTERM
Tue Apr 11 10:29:58 2023 daemon.notice netifd: tethering (7995): udhcpc: unicasting a release of 172.20.10.2 to 172.20.10.1
Tue Apr 11 10:29:58 2023 daemon.notice netifd: tethering (7995): udhcpc: sending release
Tue Apr 11 10:29:58 2023 daemon.notice netifd: tethering (7995): udhcpc: can't bind to interface eth3: No such device
Tue Apr 11 10:29:58 2023 daemon.notice netifd: tethering (7995): udhcpc: bindtodevice: No such device
Tue Apr 11 10:29:58 2023 daemon.notice netifd: tethering (7995): udhcpc: entering released state
// disconnect iPhone
Tue Apr 11 10:29:58 2023 kern.info kernel: [30268.846581] ipheth 1-1:4.2: Apple iPhone USB Ethernet now disconnected
Tue Apr 11 10:29:58 2023 daemon.notice netifd: tethering (7995): Command failed: Permission denied
Tue Apr 11 10:29:58 2023 daemon.notice netifd: Interface 'tethering' is now down
Tue Apr 11 10:29:58 2023 daemon.notice netifd: Interface 'tethering' is disabled
Tue Apr 11 10:29:58 2023 daemon.warn dnsmasq[4480]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Tue Apr 11 10:29:58 2023 user.notice mwan3track[8261]: Stopping mwan3track for interface "tethering"
Tue Apr 11 10:29:58 2023 user.notice mwan3[28957]: Execute ifdown event on interface tethering (unknown)
Tue Apr 11 10:29:59 2023 user.notice firewall: Reloading firewall due to ifdown of tethering ()
Tue Apr 11 10:29:59 2023 kern.info kernel: [30270.126321] usb 1-1: new high-speed USB device number 3 using xhci-hcd
Tue Apr 11 10:29:59 2023 daemon.err usbmuxd[7387]: [10:29:59.911][3] Connecting to new device on location 0x10003 as ID 2
Tue Apr 11 10:29:59 2023 daemon.err usbmuxd[7387]: [10:29:59.912][3] Connected to v2.0 device 2 on location 0x10003 with serial number 500d81fcfdc68ef50fa20b424dd9fc1490e58883
Tue Apr 11 10:29:59 2023 daemon.notice netifd: Interface 'tethering' is enabled
// reconnect iPhone
Tue Apr 11 10:29:59 2023 kern.info kernel: [30270.346613] ipheth 1-1:4.2: Apple iPhone USB Ethernet device attached
Tue Apr 11 10:30:03 2023 daemon.notice netifd: Network device 'eth3' link is up
Tue Apr 11 10:30:03 2023 daemon.notice netifd: Interface 'tethering' has link connectivity
Tue Apr 11 10:30:03 2023 daemon.notice netifd: Interface 'tethering' is setting up now
Tue Apr 11 10:30:03 2023 daemon.notice netifd: tethering (30373): udhcpc: started, v1.33.2
Tue Apr 11 10:30:03 2023 daemon.notice netifd: tethering (30373): udhcpc: sending discover
Tue Apr 11 10:30:03 2023 daemon.notice netifd: tethering (30373): udhcpc: sending select for 172.20.10.2
Tue Apr 11 10:30:03 2023 daemon.notice netifd: tethering (30373): udhcpc: lease of 172.20.10.2 obtained, lease time 86400
Tue Apr 11 10:30:03 2023 daemon.info avahi-daemon[3719]: Joining mDNS multicast group on interface eth3.IPv4 with address 172.20.10.2.
Tue Apr 11 10:30:03 2023 daemon.info avahi-daemon[3719]: New relevant interface eth3.IPv4 for mDNS.
Tue Apr 11 10:30:03 2023 daemon.info avahi-daemon[3719]: Registering new address record for 172.20.10.2 on eth3.IPv4.
Tue Apr 11 10:30:03 2023 daemon.notice netifd: Interface 'tethering' is now up
Tue Apr 11 10:30:03 2023 daemon.info dnsmasq[4480]: reading /tmp/resolv.conf.d/resolv.conf.auto
Tue Apr 11 10:30:03 2023 daemon.info dnsmasq[4480]: using only locally-known addresses for domain test
Tue Apr 11 10:30:03 2023 daemon.info dnsmasq[4480]: using only locally-known addresses for domain onion
Tue Apr 11 10:30:03 2023 daemon.info dnsmasq[4480]: using only locally-known addresses for domain localhost
Tue Apr 11 10:30:03 2023 daemon.info dnsmasq[4480]: using only locally-known addresses for domain invalid
Tue Apr 11 10:30:03 2023 daemon.info dnsmasq[4480]: using only locally-known addresses for domain bind
Tue Apr 11 10:30:03 2023 daemon.info dnsmasq[4480]: using only locally-known addresses for domain lan
Tue Apr 11 10:30:03 2023 daemon.info dnsmasq[4480]: using nameserver 172.20.10.1#53
Tue Apr 11 10:30:04 2023 user.notice mwan3[30386]: Execute ifup event on interface tethering (eth3)
Tue Apr 11 10:30:04 2023 user.notice mwan3[30386]: Starting tracker on interface tethering (eth3)
Tue Apr 11 10:30:06 2023 user.info mwan3rtmon[4244]: Detect rtchange event.
Tue Apr 11 10:30:06 2023 user.notice firewall: Reloading firewall due to ifup of tethering (eth3)
Tue Apr 11 10:31:53 2023 daemon.notice hostapd: wlan1: AP-STA-POLL-OK 7a:66:ef:f4:06:d4
Tue Apr 11 10:35:05 2023 daemon.info hostapd: wlan1: STA bc:ce:25:25:4f:62 IEEE 802.11: authenticated
Tue Apr 11 10:35:05 2023 daemon.info hostapd: wlan1: STA bc:ce:25:25:4f:62 IEEE 802.11: associated (aid 3)
Tue Apr 11 10:35:05 2023 daemon.notice hostapd: wlan1: AP-STA-CONNECTED bc:ce:25:25:4f:62 0 0
Tue Apr 11 10:35:05 2023 daemon.info hostapd: wlan1: STA bc:ce:25:25:4f:62 RADIUS: starting accounting session DAB9E1BE4D94C154
Tue Apr 11 10:35:05 2023 daemon.info hostapd: wlan1: STA bc:ce:25:25:4f:62 WPA: pairwise key handshake completed (RSN)
Tue Apr 11 10:35:05 2023 daemon.notice hostapd: wlan1: STA-OPMODE-SMPS-MODE-CHANGED bc:ce:25:25:4f:62 static
Tue Apr 11 10:35:10 2023 daemon.info dnsmasq-dhcp[4480]: DHCPDISCOVER(br-lan) bc:ce:25:25:4f:62
Tue Apr 11 10:35:10 2023 daemon.info dnsmasq-dhcp[4480]: DHCPOFFER(br-lan) 192.168.8.187 bc:ce:25:25:4f:62
Tue Apr 11 10:35:10 2023 daemon.info dnsmasq-dhcp[4480]: DHCPREQUEST(br-lan) 192.168.8.187 bc:ce:25:25:4f:62
Tue Apr 11 10:35:10 2023 daemon.info dnsmasq-dhcp[4480]: DHCPACK(br-lan) 192.168.8.187 bc:ce:25:25:4f:62
Tue Apr 11 10:42:55 2023 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED 7a:66:ef:f4:06:d4 0 0
Tue Apr 11 10:42:55 2023 daemon.info hostapd: wlan1: STA 7a:66:ef:f4:06:d4 IEEE 802.11: disassociated due to inactivity
Tue Apr 11 10:42:56 2023 daemon.info hostapd: wlan1: STA 7a:66:ef:f4:06:d4 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
// I went for coffee, internet was working fine when I left
Tue Apr 11 11:08:06 2023 daemon.info hostapd: wlan1: STA 7a:66:ef:f4:06:d4 IEEE 802.11: authenticated
Tue Apr 11 11:08:06 2023 daemon.info hostapd: wlan1: STA 7a:66:ef:f4:06:d4 IEEE 802.11: associated (aid 1)
Tue Apr 11 11:08:06 2023 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 7a:66:ef:f4:06:d4 0 0
Tue Apr 11 11:08:06 2023 daemon.info hostapd: wlan1: STA 7a:66:ef:f4:06:d4 RADIUS: starting accounting session 76E314F36E44E18B
Tue Apr 11 11:08:06 2023 daemon.info hostapd: wlan1: STA 7a:66:ef:f4:06:d4 WPA: pairwise key handshake completed (RSN)
Tue Apr 11 11:08:07 2023 daemon.info dnsmasq-dhcp[4480]: DHCPREQUEST(br-lan) 192.168.8.221 7a:66:ef:f4:06:d4
Tue Apr 11 11:08:07 2023 daemon.info dnsmasq-dhcp[4480]: DHCPACK(br-lan) 192.168.8.221 7a:66:ef:f4:06:d4 Mikkel-s-S21
Tue Apr 11 11:09:46 2023 kern.err kernel: [32657.469107] ipheth 1-1:4.2: ipheth_rcvbulk_callback: urb status: -75
Tue Apr 11 11:10:21 2023 user.notice mwan3[22489]: Execute ifdown event on interface tethering (eth3)
Tue Apr 11 11:10:21 2023 user.notice firewall: Reloading firewall due to ifdown of tethering (eth3)
Tue Apr 11 11:10:22 2023 user.info mwan3track[30651]: Detect ifdown event on interface tethering (eth3)
Tue Apr 11 11:10:27 2023 user.notice mwan3track[30651]: Interface tethering (eth3) is offline
// internet is now gone
alzhao
May 25, 2023, 6:17am
14
I don’t think it is related to mwan3. Seems that the USB connection or power issue.
What is the iPhone model? What is the battery level when having problems?
I was using an iphone 8 (Company phone). I was connected with an official Apple cable. Power was 100%
