GL-AR750S-EXT (Slate) Use Toggle Button for WiFi On/Off
Are there any details available that show how you can use the Toggle Button to turn the WiFi On/Off.
i.e. Setup unit to use either 2.4G or 5G then use the Toggle button to turn that WiFi setting On/Off
All solved, used the Luci app from the Software list and it works a treat so far. Set the schedule for days and times that you want, configure and set On the 2.4, 5 or both you want to use. WiFi is Enabled and Disabled by a Cron task for your selection. In the standard UI the appropriate wifi toggle is always shown as On, but is only accessible during the times you have specified.
luci-app-wifischedule git-21.189.23240-7b931da-1 Turns WiFi on and off according to a schedule
