I’m using the GLAR750S in client mode. I use the 2.4 Ghz radio to connect to the office guest wifi and I connect my devices to the router via ethernet over a simple unmanaged switch.
The 5 Ghz and 2.4 Ghz SSIDs are disabled, no clients can connect to this router via wifi. The 2.4 Ghz radio is only used to connect to the office wifi network.
Signal where the router is fairly decent, however, I’m experiencing disconnections… for instance router will stay connected to the guesf wifi for 6-7 hours then it will disconnect and won’t connect back. I have to manually logon to the router and connect back to the guest wifi.
A disconnection every now and then is not a problem, but it not connecting back automatically is a problem as I’m not in this office all the time, and I have devices which I connect to remotely - not sure why this is happening.
The router could be getting too warm. Make sure the air vents are open, not covered up. Use a fan like the
AC Infinity MULTIFAN S5, Quiet Dual 80mm USB Fan from Amazon.com. This dual fan will keep your router from getting too warm. By keeping the router’s vents open and the router cooler the router may not disconnect anymore.
