I don 't know how to setup the stick manully. My hope was not to do that.
attached a screen of my manual setup.
I found some information about the Huawai AT Commands:
AT^SETPORT? - show current mode
AT^SETPORT=? - show available modes
^SETPORT:1: 3G MODEM
^SETPORT:2: 3G PCUI
^SETPORT:3: 3G DIAG
^SETPORT:5: 3G GPS
^SETPORT:A: BLUE TOOTH
^SETPORT:16: NCM
^SETPORT:A1: CDROM
^SETPORT:A2: SD
^SETPORT:10: 4G MODEM
^SETPORT:12: 4G PCUI
^SETPORT:13: 4G DIAG
^SETPORT:14: 4G GPS
This was the default port set on my first try: AT^SETPORT:A1,A2;12,16,A1,A2
I changed it now to this port set: AT^SETPORT=“FF;10,12,16”
I found that on another Forum
But no Luck with this port set too. It doen’t connect on the GL-AR750S but on Windows.
In the Router I found some connection logging on the System Log. Maybe this helps to find out why its not connecting:
Sun Aug 11 13:11:28 2019 daemon.notice netifd: Interface ‘modem_1_1’ is now down
Sun Aug 11 13:11:28 2019 daemon.notice netifd: Interface ‘modem_1_1’ is setting up now
Sun Aug 11 13:11:31 2019 daemon.notice netifd: modem_1_1 (23224): Trying to set mode
Sun Aug 11 13:11:31 2019 daemon.notice netifd: modem_1_1 (23224): Error setting WWAN mode!
Sun Aug 11 13:11:31 2019 daemon.notice netifd: modem_1_1 (23224): cat: can’t open ‘/tmp/modem.1-1/signal’: No such file or directory
Sun Aug 11 13:11:31 2019 daemon.notice pppd[23397]: pppd 2.4.7 started by root, uid 0
Sun Aug 11 13:11:32 2019 local2.info chat[23414]: abort on (BUSY)
Sun Aug 11 13:11:32 2019 local2.info chat[23414]: abort on (NO CARRIER)
Sun Aug 11 13:11:32 2019 local2.info chat[23414]: abort on (ERROR)
Sun Aug 11 13:11:32 2019 local2.info chat[23414]: report (CONNECT)
Sun Aug 11 13:11:32 2019 local2.info chat[23414]: timeout set to 10 seconds
Sun Aug 11 13:11:32 2019 local2.info chat[23414]: send (AT+CGDCONT=1,“IP”,“internet.eplus.de”^M)
Sun Aug 11 13:11:33 2019 local2.info chat[23414]: timeout set to 30 seconds
Sun Aug 11 13:11:33 2019 local2.info chat[23414]: expect (OK)
Sun Aug 11 13:11:33 2019 local2.info chat[23414]: ^M
Sun Aug 11 13:11:33 2019 local2.info chat[23414]: OK
Sun Aug 11 13:11:33 2019 local2.info chat[23414]: – got it
Sun Aug 11 13:11:33 2019 local2.info chat[23414]: send (ATD99**1#^M)
Sun Aug 11 13:11:33 2019 local2.info chat[23414]: expect (CONNECT)
Sun Aug 11 13:11:33 2019 local2.info chat[23414]: +CME ERROR
Sun Aug 11 13:11:33 2019 local2.info chat[23414]: – failed
Sun Aug 11 13:11:33 2019 local2.info chat[23414]: Failed (ERROR)
Sun Aug 11 13:11:33 2019 daemon.err pppd[23397]: Connect script failed
Sun Aug 11 13:11:34 2019 daemon.info pppd[23397]: Exit.
