on my device I can´t find Huawei E3372 or E3276 Stick on WebIF, not on Modem or on Tethering.
On compatible list, both devices are listet, so, whot I´m doing wrong?
Newest Firmware from 3.025 is installed.
Need help, please!
Greets
Byte
Need help, please!
Greets
Byte
Can you ssh to the router and get log using the following command?
dmesg
logread
ifconfig -a
Huawei is changing hardware without changing the model name.
E3372
dmesg
[ 0.000000] Linux version 4.9.120 (lancer@gl-inet) (gcc version 7.3.0 (OpenWr t GCC 7.3.0 r7258-5eb055306f) ) #0 Thu Aug 16 07:51:15 2018
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU0 revision is: 00019750 (MIPS 74Kc)
[ 0.000000] SoC: Qualcomm Atheros QCA956X ver 1 rev 0
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 08000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] On node 0 totalpages: 32768
[ 0.000000] free_area_init_node: node 0, pgdat 805237b4, node_mem_map 8100002 0
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 32768 pages, LIFO batch:7
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 32512
[ 0.000000] Kernel command line: board=GL-AR750S console=ttyS0,115200 mtdpar ts=spi0.0:256k(u-boot)ro,64k(u-boot-env),64k(art)ro,2048k(kernel),13052k(reserve d);spi0.1:-(ubi) rootfstype=squashfs noinitrd
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 124164K/131072K available (3816K kernel code, 163K rwdata , 900K rodata, 232K init, 219K bss, 6908K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:51
[ 0.000000] Clocks: CPU:775.000MHz, DDR:650.000MHz, AHB:258.333MHz, Ref:25.00 0MHz
[ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_i dle_ns: 4932285024 ns
[ 0.000007] sched_clock: 32 bits at 387MHz, resolution 2ns, wraps every 55418 93118ns
[ 0.008222] Calibrating delay loop... 385.84 BogoMIPS (lpj=1929216)
[ 0.071045] pid_max: default: 32768 minimum: 301
[ 0.076000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.082975] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.092756] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 19112604462750000 ns
[ 0.103160] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.110635] NET: Registered protocol family 16
[ 0.116621] MIPS: machine is GL-AR750S
[ 0.360136] registering PCI controller with io_map_base unset
[ 0.382278] usbcore: registered new interface driver usbfs
[ 0.388171] usbcore: registered new interface driver hub
[ 0.393823] usbcore: registered new device driver usb
[ 0.399344] i2c-gpio i2c-gpio.0: using pins 5 (SDA) and 21 (SCL)
[ 0.405872] PCI host bridge to bus 0000:00
[ 0.410231] pci_bus 0000:00: root bus resource [mem 0x12000000-0x13ffffff]
[ 0.417468] pci_bus 0000:00: root bus resource [io 0x0001]
[ 0.423347] pci_bus 0000:00: root bus resource [??? 0x00000000 flags 0x0]
[ 0.430499] pci_bus 0000:00: No busn resource found for root bus, will use [b us 00-ff]
[ 0.438879] pci 0000:00:00.0: [168c:0050] type 00 class 0x028000
[ 0.438888] pci 0000:00:00.0: invalid calibration data
[ 0.444325] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
[ 0.444372] pci 0000:00:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 0.444437] pci 0000:00:00.0: supports D1
[ 0.444444] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 0.444627] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 00
[ 0.444651] pci 0000:00:00.0: BAR 0: assigned [mem 0x12000000-0x121fffff 64bi t]
[ 0.452395] pci 0000:00:00.0: BAR 6: assigned [mem 0x12200000-0x1220ffff pref ]
[ 0.460012] pci 0000:00:00.0: using irq 40 for pin 1
[ 0.468552] clocksource: Switched to clocksource MIPS
[ 0.474793] NET: Registered protocol family 2
[ 0.480216] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.487577] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.494319] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.501104] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.507270] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.514126] NET: Registered protocol family 1
[ 0.518780] PCI: CLS 0 bytes, default 32
[ 0.521183] Crashlog allocated RAM at address 0x3f00000
[ 0.527629] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 0.540473] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.546618] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORIT Y) (c) 2001-2006 Red Hat, Inc.
[ 0.565545] io scheduler noop registered
[ 0.569722] io scheduler deadline registered (default)
[ 0.575506] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.584385] console [ttyS0] disabled
[ 0.608227] serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11, base_baud = 156 2500) is a 16550A
[ 0.617325] console [ttyS0] enabled
[ 0.624883] bootconsole [early0] disabled
[ 0.638773] m25p80 spi0.0: found w25q128, expected m25p80
[ 0.653652] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.658563] 5 cmdlinepart partitions found on MTD device spi0.0
[ 0.664673] Creating 5 MTD partitions on "spi0.0":
[ 0.669638] 0x000000000000-0x000000040000 : "u-boot"
[ 0.676404] 0x000000040000-0x000000050000 : "u-boot-env"
[ 0.683614] 0x000000050000-0x000000060000 : "art"
[ 0.690246] 0x000000060000-0x000000260000 : "kernel"
[ 0.697080] 0x000000260000-0x000000f1f000 : "reserved"
[ 0.704572] spi-nand: Giga SPI NAND was found.
[ 0.709215] spi-nand: 128 MiB, block size: 128 KiB, page size: 2048, OOB size : 128
[ 0.717403] 1 cmdlinepart partitions found on MTD device spi0.1
[ 0.723548] Creating 1 MTD partitions on "spi0.1":
[ 0.728503] 0x000000000000-0x000008000000 : "ubi"
[ 1.126312] found bad block 6000000
[ 1.174158] found bad block 7960000
[ 1.177988] found bad block 7980000
[ 1.192711] found bad block 7fe0000
[ 1.196931] libphy: Fixed MDIO Bus: probed
[ 1.210882] switch0: Atheros AR8337 rev. 2 switch registered on ag71xx-mdio.0
[ 1.934551] libphy: ag71xx_mdio: probed
[ 2.569998] ag71xx ag71xx.0: connected to PHY at ag71xx-mdio.0:00 [uid=004dd0 36, driver=Atheros AR8216/AR8236/AR8316]
[ 2.581555] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode:SGMII
[ 2.588073] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.594853] ehci-pci: EHCI PCI platform driver
[ 2.599450] random: fast init done
[ 2.603124] usbcore: registered new interface driver usbtest
[ 2.609057] usbcore: registered new interface driver usb_ehset_test
[ 2.615574] usbcore: registered new interface driver lvs
[ 2.622552] NET: Registered protocol family 10
[ 2.631236] NET: Registered protocol family 17
[ 2.635873] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.649373] 8021q: 802.1Q VLAN Support v1.8
[ 2.658932] UBI: auto-attach mtd5
[ 2.662379] ubi0: attaching mtd5
[ 7.317203] ubi0: scanning is finished
[ 7.372358] ubi0: attached mtd5 (name "ubi", size 128 MiB)
[ 7.378028] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 7.385164] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 7.392184] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 7.399378] ubi0: good PEBs: 1020, bad PEBs: 4, corrupted PEBs: 0
[ 7.405667] ubi0: user volume: 2, internal volumes: 1, max. volumes count: 12 8
[ 7.413134] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequ ence number: 1751850999
[ 7.422567] ubi0: available PEBs: 0, total reserved PEBs: 1020, PEBs reserved for bad PEB handling: 16
[ 7.432246] ubi0: background thread "ubi_bgt0d" started, PID 352
[ 7.441883] block ubiblock0_0: created from ubi0:0(rootfs)
[ 7.447556] ubiblock: device ubiblock0_0 (rootfs) set to be root filesystem
[ 7.454793] hctosys: unable to open rtc device (rtc0)
[ 7.479054] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
[ 7.487670] Freeing unused kernel memory: 232K
[ 7.492293] This architecture does not have kernel memory protection.
[ 8.422076] init: Console is alive
[ 8.425776] init: - watchdog -
[ 11.314393] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 11.514264] exFAT: Version 1.2.9
[ 11.553503] SCSI subsystem initialized
[ 11.562045] ehci-platform: EHCI generic platform driver
[ 11.567511] ehci-platform ehci-platform.0: EHCI Host Controller
[ 11.573831] ehci-platform ehci-platform.0: new USB bus registered, assigned b us number 1
[ 11.584306] ehci-platform ehci-platform.0: irq 48, io mem 0x1b000000
[ 11.618592] ehci-platform ehci-platform.0: USB 2.0 started, EHCI 1.00
[ 11.625428] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 11.632471] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 11.639937] usb usb1: Product: EHCI Host Controller
[ 11.644975] usb usb1: Manufacturer: Linux 4.9.120 ehci_hcd
[ 11.650654] usb usb1: SerialNumber: ehci-platform.0
[ 11.656383] hub 1-0:1.0: USB hub found
[ 11.660520] hub 1-0:1.0: 1 port detected
[ 11.664865] ehci-platform ehci-platform.1: EHCI Host Controller
[ 11.671175] ehci-platform ehci-platform.1: new USB bus registered, assigned b us number 2
[ 11.681652] ehci-platform ehci-platform.1: irq 49, io mem 0x1b400000
[ 11.708590] ehci-platform ehci-platform.1: USB 2.0 started, EHCI 1.00
[ 11.715394] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 11.722432] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 11.729900] usb usb2: Product: EHCI Host Controller
[ 11.734935] usb usb2: Manufacturer: Linux 4.9.120 ehci_hcd
[ 11.740613] usb usb2: SerialNumber: ehci-platform.1
[ 11.746338] hub 2-0:1.0: USB hub found
[ 11.750480] hub 2-0:1.0: 1 port detected
[ 11.757378] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 11.765168] ohci-platform: OHCI generic platform driver
[ 11.773024] uhci_hcd: USB Universal Host Controller Interface driver
[ 11.783770] usbcore: registered new interface driver usb-storage
[ 11.791846] usbcore: registered new interface driver uas
[ 11.797959] kmodloader: done loading kernel modules from /etc/modules-boot.d/ *
[ 11.807724] init: - preinit -
[ 12.738427] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 13.010326] usb 2-1: New USB device found, idVendor=05e3, idProduct=0618
[ 13.017273] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 13.024668] usb 2-1: Product: USB2.0 Hub
[ 13.080737] hub 2-1:1.0: USB hub found
[ 13.088524] hub 2-1:1.0: 4 ports detected
[ 13.109367] random: procd: uninitialized urandom read (4 bytes read)
[ 13.489150] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.578574] usb 2-1.1: new high-speed USB device number 3 using ehci-platform
[ 13.732925] usb 2-1.1: New USB device found, idVendor=05e3, idProduct=0752
[ 13.740061] usb 2-1.1: New USB device strings: Mfr=3, Product=4, SerialNumber =0
[ 13.747621] usb 2-1.1: Product: USB Storage
[ 13.751951] usb 2-1.1: Manufacturer: Generic
[ 13.757643] usb-storage 2-1.1:1.0: USB Mass Storage device detected
[ 13.764834] scsi host0: usb-storage 2-1.1:1.0
[ 14.520218] eth0: link up (1000Mbps/Full duplex)
[ 14.525193] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 14.840288] scsi 0:0:0:0: Direct-Access Generic STORAGE DEVICE 0233 PQ : 0 ANSI: 0
[ 14.853592] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 16.758825] UBIFS (ubi0:1): background thread "ubifs_bgt0_1" started, PID 471
[ 17.026937] UBIFS (ubi0:1): recovery needed
[ 17.643922] UBIFS (ubi0:1): recovery completed
[ 17.648632] UBIFS (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name "root fs_data"
[ 17.656717] UBIFS (ubi0:1): LEB size: 126976 bytes (124 KiB), min./max. I/O u nit sizes: 2048 bytes/2048 bytes
[ 17.666973] UBIFS (ubi0:1): FS size: 114786304 bytes (109 MiB, 904 LEBs), jou rnal size 5713920 bytes (5 MiB, 45 LEBs)
[ 17.677933] UBIFS (ubi0:1): reserved for root: 4952683 bytes (4836 KiB)
[ 17.684774] UBIFS (ubi0:1): media format: w4/r0 (latest is w4/r0), UUID 69034 797-B4F1-4CC3-A795-39F7FD145487, small LPT model
[ 17.734024] mount_root: switching to ubifs overlay
[ 17.836770] urandom-seed: Seeding with /etc/urandom.seed
[ 18.046216] eth0: link down
[ 18.059323] procd: - early -
[ 18.062384] procd: - watchdog -
[ 18.713105] procd: - watchdog -
[ 18.716551] procd: - ubus -
[ 18.971925] random: ubusd: uninitialized urandom read (4 bytes read)
[ 19.086142] random: ubusd: uninitialized urandom read (4 bytes read)
[ 19.097055] random: jshn: uninitialized urandom read (4 bytes read)
[ 19.104721] procd: - init -
[ 21.526568] kmodloader: loading kernel modules from /etc/modules.d/*
[ 21.575633] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[ 21.607476] tun: Universal TUN/TAP device driver, 1.6
[ 21.612746] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 21.657153] GobiNet: 2018-12-21/SWI_2.55
[ 21.662675] usbcore: registered new interface driver GobiNet
[ 21.701632] usbcore: registered new interface driver usbserial
[ 21.707735] usbcore: registered new interface driver usbserial_generic
[ 21.714614] usbserial: USB Serial support registered for generic
[ 21.739723] usbcore: registered new interface driver GobiSerial
[ 21.745912] usbserial: USB Serial support registered for GobiSerial
[ 21.752450] GobiSerial: 2015-08-27/SWI_2.25:GobiSerial
[ 21.782723] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 21.813914] Netfilter messages via NETLINK v0.30.
[ 21.830674] ip_set: protocol 6
[ 21.924410] u32 classifier
[ 21.927208] input device check on
[ 21.931030] Actions configured
[ 21.950937] Mirror/redirect action on
[ 21.968178] nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
[ 22.049381] fuse init (API version 7.26)
[ 22.076192] usbcore: registered new interface driver cdc_acm
[ 22.082095] cdc_acm: USB Abstract Control Model driver for USB modems and ISD N adapters
[ 22.110154] usbcore: registered new interface driver cdc_ether
[ 22.131387] usbcore: registered new interface driver cdc_ncm
[ 22.145556] usbcore: registered new interface driver cdc_wdm
[ 22.160296] Loading modules backported from Linux version wt-2017-11-01-0-gfe 248fc2c180
[ 22.168610] Backport generated by backports.git v4.14-rc2-1-31-g86cf0e5d
[ 22.194267] usbcore: registered new interface driver cp210x
[ 22.200156] usbserial: USB Serial support registered for cp210x
[ 22.231707] usbcore: registered new interface driver huawei_cdc_ncm
[ 22.250753] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 22.269846] usbcore: registered new interface driver ipheth
[ 22.407390] ctnetlink v0.93: registering with nfnetlink.
[ 22.590175] usbcore: registered new interface driver qmi_wwan
[ 22.620979] usbcore: registered new interface driver rndis_host
[ 22.629119] usbcore: registered new interface driver sierra
[ 22.634951] usbserial: USB Serial support registered for Sierra USB modem
[ 22.661218] usbcore: registered new interface driver sierra_net
[ 22.694605] wireguard: WireGuard 0.0.20181119 loaded. See www.wireguard.com f or information.
[ 22.703387] wireguard: Copyright (C) 2015-2018 Jason A. Donenfeld <Jason@zx2c 4.com>. All Rights Reserved.
[ 22.819646] xt_time: kernel timezone is -0000
[ 23.075114] usbcore: registered new interface driver option
[ 23.081009] usbserial: USB Serial support registered for GSM modem (1-port)
[ 23.125093] PPP generic driver version 2.4.2
[ 23.149069] PPP MPPE Compression module registered
[ 23.172278] NET: Registered protocol family 24
[ 23.309917] PCI: Enabling device 0000:00:00.0 (0000 -> 0002)
[ 23.318017] ath10k_pci 0000:00:00.0: pci irq legacy oper_irq_mode 1 irq_mode 0 reset_mode 0
[ 23.738319] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/pre-cal- pci-0000:00:00.0.bin failed with error -2
[ 23.749422] ath10k_pci 0000:00:00.0: Falling back to user helper
[ 32.022501] firmware ath10k!pre-cal-pci-0000:00:00.0.bin: firmware_loading_st ore: map pages failed
[ 32.050562] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA9887/ hw1.0/firmware-6.bin failed with error -2
[ 32.061653] ath10k_pci 0000:00:00.0: Falling back to user helper
[ 32.315615] firmware ath10k!QCA9887!hw1.0!firmware-6.bin: firmware_loading_st ore: map pages failed
[ 32.503916] ath10k_pci 0000:00:00.0: qca9887 hw1.0 target 0x4100016d chip_id 0x004000ff sub 0000:0000
[ 32.513498] ath10k_pci 0000:00:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
[ 32.526278] ath10k_pci 0000:00:00.0: firmware ver 10.2.4-1.0-00033 api 5 feat ures no-p2p,ignore-otp,skip-clock-init,mfp,allows-mesh-bcast crc32 c232a0c3
[ 32.573128] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA9887/ hw1.0/board-2.bin failed with error -2
[ 32.583926] ath10k_pci 0000:00:00.0: Falling back to user helper
[ 32.651398] firmware ath10k!QCA9887!hw1.0!board-2.bin: firmware_loading_store : map pages failed
[ 32.675597] ath10k_pci 0000:00:00.0: board_file api 1 bmi_id N/A crc32 546cca 0d
[ 33.728997] ath10k_pci 0000:00:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal file m ax-sta 128 raw 0 hwcrypto 1
[ 33.869982] ath: EEPROM regdomain: 0x0
[ 33.869990] ath: EEPROM indicates default country code should be used
[ 33.869993] ath: doing EEPROM country->regdmn map search
[ 33.870004] ath: country maps to regdmn code: 0x3a
[ 33.870008] ath: Country alpha2 being used: US
[ 33.870010] ath: Regpair used: 0x3a
[ 33.975030] usbcore: registered new interface driver rt2800usb
[ 34.062264] ath: EEPROM regdomain: 0x0
[ 34.062272] ath: EEPROM indicates default country code should be used
[ 34.062274] ath: doing EEPROM country->regdmn map search
[ 34.062287] ath: country maps to regdmn code: 0x3a
[ 34.062291] ath: Country alpha2 being used: US
[ 34.062293] ath: Regpair used: 0x3a
[ 34.072258] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[ 34.075851] ieee80211 phy1: Atheros AR9561 Rev:0 mem=0xb8100000, irq=47
[ 34.086586] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 48.667503] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 48.675447] eth0: link up (1000Mbps/Full duplex)
[ 48.688749] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 48.700175] br-lan: port 1(eth0.1) entered blocking state
[ 48.705759] br-lan: port 1(eth0.1) entered disabled state
[ 48.711716] device eth0.1 entered promiscuous mode
[ 48.716687] device eth0 entered promiscuous mode
[ 48.759891] br-lan: port 1(eth0.1) entered blocking state
[ 48.765479] br-lan: port 1(eth0.1) entered forwarding state
[ 48.771402] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[ 49.778444] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[ 57.816987] fast-classifier: starting up
[ 57.852153] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 57.860415] fast-classifier: registered
[ 57.882027] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
[ 57.911575] br-lan: port 2(wlan0) entered blocking state
[ 57.917069] br-lan: port 2(wlan0) entered disabled state
[ 57.922961] device wlan0 entered promiscuous mode
[ 57.941500] br-lan: port 3(wlan1) entered blocking state
[ 57.947073] br-lan: port 3(wlan1) entered disabled state
[ 57.952955] device wlan1 entered promiscuous mode
[ 57.957870] br-lan: port 3(wlan1) entered blocking state
[ 57.963397] br-lan: port 3(wlan1) entered forwarding state
[ 59.871715] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[ 60.963836] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 60.970631] br-lan: port 2(wlan0) entered blocking state
[ 60.976122] br-lan: port 2(wlan0) entered forwarding state
[ 83.448588] random: crng init done
[ 83.452116] random: 6 urandom warning(s) missed due to ratelimiting
[ 155.862537] IPv6: ADDRCONF(NETDEV_UP): eth0.2: link is not ready
[ 155.868853] IPv6: ADDRCONF(NETDEV_CHANGE): eth0.2: link becomes ready
[ 168.220536] IPv6: ADDRCONF(NETDEV_UP): eth0.2: link is not ready
[ 168.226829] IPv6: ADDRCONF(NETDEV_CHANGE): eth0.2: link becomes ready
logread
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 0.000000] Linux version 4.9.120 (lancer@gl-inet) (gcc version 7.3.0 (OpenWrt GCC 7.3.0 r7258-5eb055306f) ) #0 Thu Aug 16 07:51:15 2018
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] bootconsole [early0] enabled
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] CPU0 revision is: 00019750 (MIPS 74Kc)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] SoC: Qualcomm Atheros QCA956X ver 1 rev 0
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] Determined physical RAM map:
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] memory: 08000000 @ 00000000 (usable)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] Initrd not found or empty - disabling initrd
Mon Aug 5 15:42:42 2019 kern.warn kernel: [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Mon Aug 5 15:42:42 2019 kern.warn kernel: [ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] Zone ranges:
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] Movable zone start for each node
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] Early memory node ranges
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff]
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 0.000000] On node 0 totalpages: 32768
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 0.000000] free_area_init_node: node 0, pgdat 805237b4, node_mem_map 81000020
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 0.000000] Normal zone: 256 pages used for memmap
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 0.000000] Normal zone: 32768 pages, LIFO batch:7
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 0.000000] Kernel command line: board=GL-AR750S console=ttyS0,115200 mtdparts=spi0.0:256k(u-boot)ro,64k(u-boot-env),64k(art)ro,2048k(kernel),13052k(reserved);spi0.1:-(ubi) rootfstype=squashfs noinitrd
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] Writing ErrCtl register=00000000
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] Readback ErrCtl register=00000000
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] Memory: 124164K/131072K available (3816K kernel code, 163K rwdata, 900K rodata, 232K init, 219K bss, 6908K reserved, 0K cma-reserved)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] NR_IRQS:51
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] Clocks: CPU:775.000MHz, DDR:650.000MHz, AHB:258.333MHz, Ref:25.000MHz
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 4932285024 ns
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.000007] sched_clock: 32 bits at 387MHz, resolution 2ns, wraps every 5541893118ns
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.008222] Calibrating delay loop... 385.84 BogoMIPS (lpj=1929216)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.071045] pid_max: default: 32768 minimum: 301
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.076000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.082975] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.092756] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.103160] futex hash table entries: 256 (order: -1, 3072 bytes)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.110635] NET: Registered protocol family 16
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.116621] MIPS: machine is GL-AR750S
Mon Aug 5 15:42:42 2019 kern.warn kernel: [ 0.360136] registering PCI controller with io_map_base unset
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.382278] usbcore: registered new interface driver usbfs
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.388171] usbcore: registered new interface driver hub
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.393823] usbcore: registered new device driver usb
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.399344] i2c-gpio i2c-gpio.0: using pins 5 (SDA) and 21 (SCL)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.405872] PCI host bridge to bus 0000:00
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.410231] pci_bus 0000:00: root bus resource [mem 0x12000000-0x13ffffff]
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.417468] pci_bus 0000:00: root bus resource [io 0x0001]
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.423347] pci_bus 0000:00: root bus resource [??? 0x00000000 flags 0x0]
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.430499] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 0.438879] pci 0000:00:00.0: [168c:0050] type 00 class 0x028000
Mon Aug 5 15:42:42 2019 kern.err kernel: [ 0.438888] pci 0000:00:00.0: invalid calibration data
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 0.444325] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 0.444372] pci 0000:00:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 0.444437] pci 0000:00:00.0: supports D1
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 0.444444] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 0.444627] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 00
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.444651] pci 0000:00:00.0: BAR 0: assigned [mem 0x12000000-0x121fffff 64bit]
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.452395] pci 0000:00:00.0: BAR 6: assigned [mem 0x12200000-0x1220ffff pref]
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.460012] pci 0000:00:00.0: using irq 40 for pin 1
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.468552] clocksource: Switched to clocksource MIPS
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.474793] NET: Registered protocol family 2
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.480216] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.487577] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.494319] TCP: Hash tables configured (established 1024 bind 1024)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.501104] UDP hash table entries: 256 (order: 0, 4096 bytes)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.507270] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.514126] NET: Registered protocol family 1
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 0.518780] PCI: CLS 0 bytes, default 32
Mon Aug 5 15:42:42 2019 kern.warn kernel: [ 0.521183] Crashlog allocated RAM at address 0x3f00000
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.527629] workingset: timestamp_bits=30 max_order=15 bucket_order=0
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.540473] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.546618] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.565545] io scheduler noop registered
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.569722] io scheduler deadline registered (default)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.575506] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.584385] console [ttyS0] disabled
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.608227] serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11, base_baud = 1562500) is a 16550A
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.617325] console [ttyS0] enabled
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.624883] bootconsole [early0] disabled
Mon Aug 5 15:42:42 2019 kern.warn kernel: [ 0.638773] m25p80 spi0.0: found w25q128, expected m25p80
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.653652] m25p80 spi0.0: w25q128 (16384 Kbytes)
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 0.658563] 5 cmdlinepart partitions found on MTD device spi0.0
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 0.664673] Creating 5 MTD partitions on "spi0.0":
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 0.669638] 0x000000000000-0x000000040000 : "u-boot"
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 0.676404] 0x000000040000-0x000000050000 : "u-boot-env"
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 0.683614] 0x000000050000-0x000000060000 : "art"
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 0.690246] 0x000000060000-0x000000260000 : "kernel"
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 0.697080] 0x000000260000-0x000000f1f000 : "reserved"
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.704572] spi-nand: Giga SPI NAND was found.
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 0.709215] spi-nand: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 128
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 0.717403] 1 cmdlinepart partitions found on MTD device spi0.1
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 0.723548] Creating 1 MTD partitions on "spi0.1":
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 0.728503] 0x000000000000-0x000008000000 : "ubi"
Mon Aug 5 15:42:42 2019 kern.warn kernel: [ 1.126312] found bad block 6000000
Mon Aug 5 15:42:42 2019 kern.warn kernel: [ 1.174158] found bad block 7960000
Mon Aug 5 15:42:42 2019 kern.warn kernel: [ 1.177988] found bad block 7980000
Mon Aug 5 15:42:42 2019 kern.warn kernel: [ 1.192711] found bad block 7fe0000
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 1.196931] libphy: Fixed MDIO Bus: probed
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 1.210882] switch0: Atheros AR8337 rev. 2 switch registered on ag71xx-mdio.0
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 1.934551] libphy: ag71xx_mdio: probed
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 2.569998] ag71xx ag71xx.0: connected to PHY at ag71xx-mdio.0:00 [uid=004dd036, driver=Atheros AR8216/AR8236/AR8316]
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 2.581555] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode:SGMII
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 2.588073] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 2.594853] ehci-pci: EHCI PCI platform driver
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 2.599450] random: fast init done
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 2.603124] usbcore: registered new interface driver usbtest
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 2.609057] usbcore: registered new interface driver usb_ehset_test
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 2.615574] usbcore: registered new interface driver lvs
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 2.622552] NET: Registered protocol family 10
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 2.631236] NET: Registered protocol family 17
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 2.635873] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 2.649373] 8021q: 802.1Q VLAN Support v1.8
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 2.658932] UBI: auto-attach mtd5
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 2.662379] ubi0: attaching mtd5
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 7.317203] ubi0: scanning is finished
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 7.372358] ubi0: attached mtd5 (name "ubi", size 128 MiB)
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 7.378028] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 7.385164] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 7.392184] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 7.399378] ubi0: good PEBs: 1020, bad PEBs: 4, corrupted PEBs: 0
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 7.405667] ubi0: user volume: 2, internal volumes: 1, max. volumes count: 128
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 7.413134] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 1751850999
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 7.422567] ubi0: available PEBs: 0, total reserved PEBs: 1020, PEBs reserved for bad PEB handling: 16
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 7.432246] ubi0: background thread "ubi_bgt0d" started, PID 352
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 7.441883] block ubiblock0_0: created from ubi0:0(rootfs)
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 7.447556] ubiblock: device ubiblock0_0 (rootfs) set to be root filesystem
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 7.454793] hctosys: unable to open rtc device (rtc0)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 7.479054] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 7.487670] Freeing unused kernel memory: 232K
Mon Aug 5 15:42:42 2019 kern.warn kernel: [ 7.492293] This architecture does not have kernel memory protection.
Mon Aug 5 15:42:42 2019 user.info kernel: [ 8.422076] init: Console is alive
Mon Aug 5 15:42:42 2019 user.info kernel: [ 8.425776] init: - watchdog -
Mon Aug 5 15:42:42 2019 user.info kernel: [ 11.314393] kmodloader: loading kernel modules from /etc/modules-boot.d/*
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.514264] exFAT: Version 1.2.9
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 11.553503] SCSI subsystem initialized
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.562045] ehci-platform: EHCI generic platform driver
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.567511] ehci-platform ehci-platform.0: EHCI Host Controller
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.573831] ehci-platform ehci-platform.0: new USB bus registered, assigned bus number 1
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.584306] ehci-platform ehci-platform.0: irq 48, io mem 0x1b000000
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.618592] ehci-platform ehci-platform.0: USB 2.0 started, EHCI 1.00
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.625428] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.632471] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.639937] usb usb1: Product: EHCI Host Controller
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.644975] usb usb1: Manufacturer: Linux 4.9.120 ehci_hcd
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.650654] usb usb1: SerialNumber: ehci-platform.0
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.656383] hub 1-0:1.0: USB hub found
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.660520] hub 1-0:1.0: 1 port detected
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.664865] ehci-platform ehci-platform.1: EHCI Host Controller
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.671175] ehci-platform ehci-platform.1: new USB bus registered, assigned bus number 2
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.681652] ehci-platform ehci-platform.1: irq 49, io mem 0x1b400000
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.708590] ehci-platform ehci-platform.1: USB 2.0 started, EHCI 1.00
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.715394] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.722432] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.729900] usb usb2: Product: EHCI Host Controller
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.734935] usb usb2: Manufacturer: Linux 4.9.120 ehci_hcd
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.740613] usb usb2: SerialNumber: ehci-platform.1
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.746338] hub 2-0:1.0: USB hub found
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.750480] hub 2-0:1.0: 1 port detected
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.757378] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.765168] ohci-platform: OHCI generic platform driver
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.773024] uhci_hcd: USB Universal Host Controller Interface driver
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.783770] usbcore: registered new interface driver usb-storage
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 11.791846] usbcore: registered new interface driver uas
Mon Aug 5 15:42:42 2019 user.info kernel: [ 11.797959] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Mon Aug 5 15:42:42 2019 user.info kernel: [ 11.807724] init: - preinit -
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 12.738427] usb 2-1: new high-speed USB device number 2 using ehci-platform
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 13.010326] usb 2-1: New USB device found, idVendor=05e3, idProduct=0618
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 13.017273] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 13.024668] usb 2-1: Product: USB2.0 Hub
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 13.080737] hub 2-1:1.0: USB hub found
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 13.088524] hub 2-1:1.0: 4 ports detected
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 13.109367] random: procd: uninitialized urandom read (4 bytes read)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 13.489150] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 13.578574] usb 2-1.1: new high-speed USB device number 3 using ehci-platform
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 13.732925] usb 2-1.1: New USB device found, idVendor=05e3, idProduct=0752
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 13.740061] usb 2-1.1: New USB device strings: Mfr=3, Product=4, SerialNumber=0
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 13.747621] usb 2-1.1: Product: USB Storage
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 13.751951] usb 2-1.1: Manufacturer: Generic
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 13.757643] usb-storage 2-1.1:1.0: USB Mass Storage device detected
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 13.764834] scsi host0: usb-storage 2-1.1:1.0
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 14.520218] eth0: link up (1000Mbps/Full duplex)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 14.525193] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 14.840288] scsi 0:0:0:0: Direct-Access Generic STORAGE DEVICE 0233 PQ: 0 ANSI: 0
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 14.853592] sd 0:0:0:0: [sda] Attached SCSI removable disk
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 16.758825] UBIFS (ubi0:1): background thread "ubifs_bgt0_1" started, PID 471
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 17.026937] UBIFS (ubi0:1): recovery needed
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 17.643922] UBIFS (ubi0:1): recovery completed
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 17.648632] UBIFS (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name "rootfs_data"
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 17.656717] UBIFS (ubi0:1): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 17.666973] UBIFS (ubi0:1): FS size: 114786304 bytes (109 MiB, 904 LEBs), journal size 5713920 bytes (5 MiB, 45 LEBs)
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 17.677933] UBIFS (ubi0:1): reserved for root: 4952683 bytes (4836 KiB)
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 17.684774] UBIFS (ubi0:1): media format: w4/r0 (latest is w4/r0), UUID 69034797-B4F1-4CC3-A795-39F7FD145487, small LPT model
Mon Aug 5 15:42:42 2019 user.info kernel: [ 17.734024] mount_root: switching to ubifs overlay
Mon Aug 5 15:42:42 2019 user.warn kernel: [ 17.836770] urandom-seed: Seeding with /etc/urandom.seed
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 18.046216] eth0: link down
Mon Aug 5 15:42:42 2019 user.info kernel: [ 18.059323] procd: - early -
Mon Aug 5 15:42:42 2019 user.info kernel: [ 18.062384] procd: - watchdog -
Mon Aug 5 15:42:42 2019 user.info kernel: [ 18.713105] procd: - watchdog -
Mon Aug 5 15:42:42 2019 user.info kernel: [ 18.716551] procd: - ubus -
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 18.971925] random: ubusd: uninitialized urandom read (4 bytes read)
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 19.086142] random: ubusd: uninitialized urandom read (4 bytes read)
Mon Aug 5 15:42:42 2019 kern.notice kernel: [ 19.097055] random: jshn: uninitialized urandom read (4 bytes read)
Mon Aug 5 15:42:42 2019 user.info kernel: [ 19.104721] procd: - init -
Mon Aug 5 15:42:42 2019 user.info kernel: [ 21.526568] kmodloader: loading kernel modules from /etc/modules.d/*
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 21.575633] ntfs: driver 2.1.32 [Flags: R/O MODULE].
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 21.607476] tun: Universal TUN/TAP device driver, 1.6
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 21.612746] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 21.657153] GobiNet: 2018-12-21/SWI_2.55
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 21.662675] usbcore: registered new interface driver GobiNet
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 21.701632] usbcore: registered new interface driver usbserial
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 21.707735] usbcore: registered new interface driver usbserial_generic
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 21.714614] usbserial: USB Serial support registered for generic
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 21.739723] usbcore: registered new interface driver GobiSerial
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 21.745912] usbserial: USB Serial support registered for GobiSerial
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 21.752450] GobiSerial: 2015-08-27/SWI_2.25:GobiSerial
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 21.782723] ip6_tables: (C) 2000-2006 Netfilter Core Team
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 21.813914] Netfilter messages via NETLINK v0.30.
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 21.830674] ip_set: protocol 6
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 21.924410] u32 classifier
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 21.927208] input device check on
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 21.931030] Actions configured
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 21.950937] Mirror/redirect action on
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 21.968178] nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.049381] fuse init (API version 7.26)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.076192] usbcore: registered new interface driver cdc_acm
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.082095] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.110154] usbcore: registered new interface driver cdc_ether
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.131387] usbcore: registered new interface driver cdc_ncm
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.145556] usbcore: registered new interface driver cdc_wdm
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.160296] Loading modules backported from Linux version wt-2017-11-01-0-gfe248fc2c180
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.168610] Backport generated by backports.git v4.14-rc2-1-31-g86cf0e5d
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.194267] usbcore: registered new interface driver cp210x
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.200156] usbserial: USB Serial support registered for cp210x
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.231707] usbcore: registered new interface driver huawei_cdc_ncm
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.250753] ip_tables: (C) 2000-2006 Netfilter Core Team
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.269846] usbcore: registered new interface driver ipheth
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.407390] ctnetlink v0.93: registering with nfnetlink.
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.590175] usbcore: registered new interface driver qmi_wwan
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.620979] usbcore: registered new interface driver rndis_host
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.629119] usbcore: registered new interface driver sierra
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.634951] usbserial: USB Serial support registered for Sierra USB modem
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.661218] usbcore: registered new interface driver sierra_net
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.694605] wireguard: WireGuard 0.0.20181119 loaded. See www.wireguard.com for information.
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.703387] wireguard: Copyright (C) 2015-2018 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 22.819646] xt_time: kernel timezone is -0000
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 23.075114] usbcore: registered new interface driver option
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 23.081009] usbserial: USB Serial support registered for GSM modem (1-port)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 23.125093] PPP generic driver version 2.4.2
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 23.149069] PPP MPPE Compression module registered
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 23.172278] NET: Registered protocol family 24
Mon Aug 5 15:42:42 2019 kern.warn kernel: [ 23.309917] PCI: Enabling device 0000:00:00.0 (0000 -> 0002)
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 23.318017] ath10k_pci 0000:00:00.0: pci irq legacy oper_irq_mode 1 irq_mode 0 reset_mode 0
Mon Aug 5 15:42:42 2019 kern.warn kernel: [ 23.738319] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:00:00.0.bin failed with error -2
Mon Aug 5 15:42:42 2019 kern.warn kernel: [ 23.749422] ath10k_pci 0000:00:00.0: Falling back to user helper
Mon Aug 5 15:42:42 2019 kern.err kernel: [ 32.022501] firmware ath10k!pre-cal-pci-0000:00:00.0.bin: firmware_loading_store: map pages failed
Mon Aug 5 15:42:42 2019 kern.warn kernel: [ 32.050562] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA9887/hw1.0/firmware-6.bin failed with error -2
Mon Aug 5 15:42:42 2019 kern.warn kernel: [ 32.061653] ath10k_pci 0000:00:00.0: Falling back to user helper
Mon Aug 5 15:42:42 2019 kern.err kernel: [ 32.315615] firmware ath10k!QCA9887!hw1.0!firmware-6.bin: firmware_loading_store: map pages failed
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 32.503916] ath10k_pci 0000:00:00.0: qca9887 hw1.0 target 0x4100016d chip_id 0x004000ff sub 0000:0000
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 32.513498] ath10k_pci 0000:00:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 32.526278] ath10k_pci 0000:00:00.0: firmware ver 10.2.4-1.0-00033 api 5 features no-p2p,ignore-otp,skip-clock-init,mfp,allows-mesh-bcast crc32 c232a0c3
Mon Aug 5 15:42:42 2019 kern.warn kernel: [ 32.573128] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA9887/hw1.0/board-2.bin failed with error -2
Mon Aug 5 15:42:42 2019 kern.warn kernel: [ 32.583926] ath10k_pci 0000:00:00.0: Falling back to user helper
Mon Aug 5 15:42:42 2019 kern.err kernel: [ 32.651398] firmware ath10k!QCA9887!hw1.0!board-2.bin: firmware_loading_store: map pages failed
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 32.675597] ath10k_pci 0000:00:00.0: board_file api 1 bmi_id N/A crc32 546cca0d
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 33.728997] ath10k_pci 0000:00:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal file max-sta 128 raw 0 hwcrypto 1
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 33.869982] ath: EEPROM regdomain: 0x0
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 33.869990] ath: EEPROM indicates default country code should be used
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 33.869993] ath: doing EEPROM country->regdmn map search
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 33.870004] ath: country maps to regdmn code: 0x3a
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 33.870008] ath: Country alpha2 being used: US
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 33.870010] ath: Regpair used: 0x3a
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 33.975030] usbcore: registered new interface driver rt2800usb
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 34.062264] ath: EEPROM regdomain: 0x0
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 34.062272] ath: EEPROM indicates default country code should be used
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 34.062274] ath: doing EEPROM country->regdmn map search
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 34.062287] ath: country maps to regdmn code: 0x3a
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 34.062291] ath: Country alpha2 being used: US
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 34.062293] ath: Regpair used: 0x3a
Mon Aug 5 15:42:42 2019 kern.debug kernel: [ 34.072258] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
Mon Aug 5 15:42:42 2019 kern.info kernel: [ 34.075851] ieee80211 phy1: Atheros AR9561 Rev:0 mem=0xb8100000, irq=47
Mon Aug 5 15:42:42 2019 user.info kernel: [ 34.086586] kmodloader: done loading kernel modules from /etc/modules.d/*
Mon Aug 5 15:42:43 2019 daemon.notice procd: /etc/rc.d/S18firewall_gl: uci: Entry not found
Mon Aug 5 15:42:44 2019 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Mon Aug 5 15:42:44 2019 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Mon Aug 5 15:42:45 2019 daemon.info dnsmasq[1563]: started, version 2.80test2 cachesize 150
Mon Aug 5 15:42:45 2019 daemon.info dnsmasq[1563]: DNS service limited to local subnets
Mon Aug 5 15:42:45 2019 daemon.info dnsmasq[1563]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Mon Aug 5 15:42:45 2019 daemon.info dnsmasq[1563]: using local addresses only for domain test
Mon Aug 5 15:42:45 2019 daemon.info dnsmasq[1563]: using local addresses only for domain onion
Mon Aug 5 15:42:45 2019 daemon.info dnsmasq[1563]: using local addresses only for domain localhost
Mon Aug 5 15:42:45 2019 daemon.info dnsmasq[1563]: using local addresses only for domain invalid
Mon Aug 5 15:42:45 2019 daemon.info dnsmasq[1563]: using local addresses only for domain bind
Mon Aug 5 15:42:45 2019 daemon.info dnsmasq[1563]: using local addresses only for domain lan
Mon Aug 5 15:42:45 2019 daemon.warn dnsmasq[1563]: no servers found in /tmp/resolv.conf.auto, will retry
Mon Aug 5 15:42:45 2019 daemon.info dnsmasq[1563]: read /etc/hosts - 4 addresses
Mon Aug 5 15:42:45 2019 daemon.info dnsmasq[1563]: read /tmp/hosts/dhcp.cfg01411c - 1 addresses
Mon Aug 5 15:42:49 2019 user.notice : Added device handler type: tunnel
Mon Aug 5 15:42:49 2019 user.notice : Added device handler type: Network device
Mon Aug 5 15:42:49 2019 user.notice : Added device handler type: bridge
Mon Aug 5 15:42:49 2019 user.notice : Added device handler type: veth
Mon Aug 5 15:42:49 2019 user.notice : Added device handler type: macvlan
Mon Aug 5 15:42:49 2019 user.notice : Added device handler type: 8021ad
Mon Aug 5 15:42:49 2019 user.notice : Added device handler type: 8021q
Mon Aug 5 15:42:50 2019 daemon.notice procd: /etc/rc.d/S21initswitch: uci: Entry not found
Mon Aug 5 15:42:50 2019 daemon.notice procd: /etc/rc.d/S30gl_ssids: uci: Entry not found
Mon Aug 5 15:42:51 2019 daemon.notice procd: /etc/init.d/gl_ssids: uci: Entry not found
Mon Aug 5 15:42:52 2019 daemon.notice procd: /etc/rc.d/S50glfw: uci: Entry not found
Mon Aug 5 15:42:53 2019 authpriv.info dropbear[1909]: Not backgrounding
Mon Aug 5 15:42:55 2019 kern.info kernel: [ 48.667503] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Mon Aug 5 15:42:55 2019 kern.info kernel: [ 48.675447] eth0: link up (1000Mbps/Full duplex)
Mon Aug 5 15:42:55 2019 kern.info kernel: [ 48.688749] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Mon Aug 5 15:42:55 2019 kern.info kernel: [ 48.700175] br-lan: port 1(eth0.1) entered blocking state
Mon Aug 5 15:42:55 2019 kern.info kernel: [ 48.705759] br-lan: port 1(eth0.1) entered disabled state
Mon Aug 5 15:42:55 2019 kern.info kernel: [ 48.711716] device eth0.1 entered promiscuous mode
Mon Aug 5 15:42:55 2019 kern.info kernel: [ 48.716687] device eth0 entered promiscuous mode
Mon Aug 5 15:42:55 2019 kern.info kernel: [ 48.759891] br-lan: port 1(eth0.1) entered blocking state
Mon Aug 5 15:42:55 2019 kern.info kernel: [ 48.765479] br-lan: port 1(eth0.1) entered forwarding state
Mon Aug 5 15:42:55 2019 kern.info kernel: [ 48.771402] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
Mon Aug 5 15:42:55 2019 daemon.notice netifd: Interface 'lan' is enabled
Mon Aug 5 15:42:55 2019 daemon.notice netifd: Interface 'lan' is setting up now
Mon Aug 5 15:42:55 2019 daemon.notice netifd: Interface 'lan' is now up
Mon Aug 5 15:42:55 2019 daemon.notice netifd: Interface 'loopback' is enabled
Mon Aug 5 15:42:55 2019 daemon.notice netifd: Interface 'loopback' is setting up now
Mon Aug 5 15:42:55 2019 daemon.notice netifd: Interface 'loopback' is now up
Mon Aug 5 15:42:55 2019 daemon.notice netifd: Interface 'wan' is enabled
Mon Aug 5 15:42:55 2019 daemon.notice netifd: Interface 'wan6' is enabled
Mon Aug 5 15:42:55 2019 daemon.notice netifd: bridge 'br-lan' link is up
Mon Aug 5 15:42:55 2019 daemon.notice netifd: Interface 'lan' has link connectivity
Mon Aug 5 15:42:55 2019 daemon.notice netifd: Network device 'eth0' link is up
Mon Aug 5 15:42:55 2019 daemon.notice netifd: VLAN 'eth0.1' link is up
Mon Aug 5 15:42:55 2019 daemon.notice netifd: Network device 'lo' link is up
Mon Aug 5 15:42:55 2019 daemon.notice netifd: Interface 'loopback' has link connectivity
Mon Aug 5 15:42:55 2019 daemon.notice netifd: VLAN 'eth0.2' link is up
Mon Aug 5 15:42:55 2019 daemon.notice netifd: Interface 'wan' has link connectivity
Mon Aug 5 15:42:55 2019 daemon.notice netifd: Interface 'wan' is setting up now
Mon Aug 5 15:42:55 2019 daemon.notice netifd: Interface 'wan6' has link connectivity
Mon Aug 5 15:42:55 2019 daemon.notice netifd: Interface 'wan6' is setting up now
Mon Aug 5 15:42:56 2019 kern.info kernel: [ 49.778444] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Mon Aug 5 15:42:56 2019 daemon.notice netifd: wan (2120): udhcpc: started, v1.28.3
Mon Aug 5 15:42:57 2019 daemon.notice netifd: wan (2120): udhcpc: sending discover
Mon Aug 5 15:43:00 2019 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Mon Aug 5 15:43:00 2019 daemon.notice netifd: wan (2120): udhcpc: sending discover
Mon Aug 5 15:43:00 2019 daemon.info dnsmasq[1563]: exiting on receipt of SIGTERM
Mon Aug 5 15:43:00 2019 daemon.info dnsmasq[2474]: started, version 2.80test2 cachesize 150
Mon Aug 5 15:43:01 2019 daemon.info dnsmasq[2474]: DNS service limited to local subnets
Mon Aug 5 15:43:01 2019 daemon.info dnsmasq[2474]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Mon Aug 5 15:43:01 2019 daemon.info dnsmasq-dhcp[2474]: DHCP, IP range 192.168.7.100 -- 192.168.7.249, lease time 12h
Mon Aug 5 15:43:01 2019 daemon.info dnsmasq[2474]: using local addresses only for domain test
Mon Aug 5 15:43:01 2019 daemon.info dnsmasq[2474]: using local addresses only for domain onion
Mon Aug 5 15:43:01 2019 daemon.info dnsmasq[2474]: using local addresses only for domain localhost
Mon Aug 5 15:43:01 2019 daemon.info dnsmasq[2474]: using local addresses only for domain invalid
Mon Aug 5 15:43:01 2019 daemon.info dnsmasq[2474]: using local addresses only for domain bind
Mon Aug 5 15:43:01 2019 daemon.info dnsmasq[2474]: using local addresses only for domain lan
Mon Aug 5 15:43:01 2019 daemon.warn dnsmasq[2474]: no servers found in /tmp/resolv.conf.auto, will retry
Mon Aug 5 15:43:01 2019 daemon.info dnsmasq[2474]: read /etc/hosts - 4 addresses
Mon Aug 5 15:43:01 2019 daemon.info dnsmasq[2474]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Mon Aug 5 15:43:01 2019 daemon.info dnsmasq-dhcp[2474]: read /etc/ethers - 0 addresses
Mon Aug 5 15:43:02 2019 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Mon Aug 5 15:43:04 2019 daemon.notice netifd: wan (2120): udhcpc: sending discover
Mon Aug 5 15:43:04 2019 daemon.err hostapd: Configuration file: /var/run/hostapd-phy1.conf
Mon Aug 5 15:43:04 2019 kern.alert kernel: [ 57.816987] fast-classifier: starting up
Mon Aug 5 15:43:04 2019 kern.info kernel: [ 57.852153] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Mon Aug 5 15:43:04 2019 kern.alert kernel: [ 57.860415] fast-classifier: registered
Mon Aug 5 15:43:04 2019 kern.info kernel: [ 57.882027] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Mon Aug 5 15:43:04 2019 kern.info kernel: [ 57.911575] br-lan: port 2(wlan0) entered blocking state
Mon Aug 5 15:43:04 2019 kern.info kernel: [ 57.917069] br-lan: port 2(wlan0) entered disabled state
Mon Aug 5 15:43:04 2019 kern.info kernel: [ 57.922961] device wlan0 entered promiscuous mode
Mon Aug 5 15:43:04 2019 kern.info kernel: [ 57.941500] br-lan: port 3(wlan1) entered blocking state
Mon Aug 5 15:43:04 2019 kern.info kernel: [ 57.947073] br-lan: port 3(wlan1) entered disabled state
Mon Aug 5 15:43:04 2019 kern.info kernel: [ 57.952955] device wlan1 entered promiscuous mode
Mon Aug 5 15:43:04 2019 kern.info kernel: [ 57.957870] br-lan: port 3(wlan1) entered blocking state
Mon Aug 5 15:43:04 2019 kern.info kernel: [ 57.963397] br-lan: port 3(wlan1) entered forwarding state
Mon Aug 5 15:43:04 2019 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->HT_SCAN
Mon Aug 5 15:43:04 2019 daemon.err hostapd: Using interface wlan1 with hwaddr e4:95:6e:46:91:ec and ssid "hotspot.gini"
Mon Aug 5 15:43:04 2019 daemon.err rmmod: module is not loaded
Mon Aug 5 15:43:05 2019 daemon.err hostapd: Using interface wlan0 with hwaddr e4:95:6e:46:91:ed and ssid "hotspot.gini"
Mon Aug 5 15:43:06 2019 kern.info kernel: [ 59.871715] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Mon Aug 5 15:43:06 2019 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->ENABLED
Mon Aug 5 15:43:06 2019 daemon.notice hostapd: wlan1: AP-ENABLED
Mon Aug 5 15:43:07 2019 daemon.notice hostapd: wlan0: interface state HT_SCAN->ENABLED
Mon Aug 5 15:43:07 2019 daemon.notice hostapd: wlan0: AP-ENABLED
Mon Aug 5 15:43:07 2019 user.notice ucitrack: Setting up /etc/config/network reload dependency on /etc/config/dhcp
Mon Aug 5 15:43:07 2019 daemon.notice netifd: Network device 'wlan1' link is up
Mon Aug 5 15:43:07 2019 user.notice ucitrack: Setting up /etc/config/network reload dependency on /etc/config/radvd
Mon Aug 5 15:43:07 2019 user.notice ucitrack: Setting up /etc/config/wireless reload dependency on /etc/config/network
Mon Aug 5 15:43:07 2019 daemon.notice netifd: Network device 'wlan0' link is up
Mon Aug 5 15:43:07 2019 kern.info kernel: [ 60.963836] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Mon Aug 5 15:43:07 2019 kern.info kernel: [ 60.970631] br-lan: port 2(wlan0) entered blocking state
Mon Aug 5 15:43:07 2019 kern.info kernel: [ 60.976122] br-lan: port 2(wlan0) entered forwarding state
Mon Aug 5 15:43:07 2019 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/luci-splash
Mon Aug 5 15:43:07 2019 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/qos
Mon Aug 5 15:43:07 2019 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/miniupnpd
Mon Aug 5 15:43:08 2019 user.notice ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/odhcpd
Mon Aug 5 15:43:08 2019 user.notice ucitrack: Setting up /etc/config/system reload trigger for non-procd /etc/init.d/led
Mon Aug 5 15:43:09 2019 user.notice ucitrack: Setting up /etc/config/system reload dependency on /etc/config/luci_statistics
Mon Aug 5 15:43:09 2019 user.notice ucitrack: Setting up /etc/config/system reload dependency on /etc/config/dhcp
Mon Aug 5 15:43:09 2019 user.notice ucitrack: Setting up /etc/config/mwan3 reload trigger for non-procd /etc/init.d/mwan3
Mon Aug 5 15:43:11 2019 daemon.notice procd: /etc/rc.d/S95done: killall: uqmi: no process killed
Mon Aug 5 15:43:11 2019 daemon.notice procd: /etc/rc.d/S96led: setting up led WLAN2G
Mon Aug 5 15:43:11 2019 daemon.notice procd: /etc/rc.d/S96led: setting up led WLAN5G
Mon Aug 5 15:43:12 2019 user.info : Sta config not set!!!!
Mon Aug 5 15:43:12 2019 daemon.notice procd: /etc/rc.d/S99gl_route_policy: uci: Entry not found
Mon Aug 5 15:43:15 2019 daemon.info procd: - init complete -
Mon Aug 5 15:43:30 2019 kern.notice kernel: [ 83.448588] random: crng init done
Mon Aug 5 15:43:30 2019 kern.notice kernel: [ 83.452116] random: 6 urandom warning(s) missed due to ratelimiting
Mon Aug 5 15:44:42 2019 daemon.err odhcp6c[2096]: Failed to send RS (Permission denied)
Mon Aug 5 15:44:42 2019 daemon.notice netifd: VLAN 'eth0.2' link is down
Mon Aug 5 15:44:42 2019 daemon.notice netifd: Interface 'wan' has link connectivity loss
Mon Aug 5 15:44:42 2019 daemon.notice netifd: Interface 'wan6' has link connectivity loss
Mon Aug 5 15:44:42 2019 daemon.notice netifd: wan (2120): udhcpc: read error: Network is down, reopening socket
Mon Aug 5 15:44:42 2019 daemon.notice netifd: VLAN 'eth0.2' link is up
Mon Aug 5 15:44:42 2019 daemon.notice netifd: Interface 'wan' is setting up now
Mon Aug 5 15:44:42 2019 daemon.notice netifd: Interface 'wan6' is setting up now
Mon Aug 5 15:44:42 2019 kern.info kernel: [ 155.862537] IPv6: ADDRCONF(NETDEV_UP): eth0.2: link is not ready
Mon Aug 5 15:44:42 2019 kern.info kernel: [ 155.868853] IPv6: ADDRCONF(NETDEV_CHANGE): eth0.2: link becomes ready
Mon Aug 5 15:44:42 2019 daemon.err odhcp6c[2096]: Failed to send DHCPV6 message to ff02::1:2 (Address not available)
Mon Aug 5 15:44:42 2019 daemon.err odhcp6c[2096]: Failed to send RS (Address not available)
Mon Aug 5 15:44:42 2019 daemon.notice netifd: wan (2120): udhcpc: received SIGTERM
Mon Aug 5 15:44:42 2019 daemon.notice netifd: Interface 'wan' is now down
Mon Aug 5 15:44:43 2019 daemon.notice netifd: wan (5627): udhcpc: started, v1.28.3
Mon Aug 5 15:44:43 2019 daemon.notice netifd: wan (5627): udhcpc: sending discover
Mon Aug 5 15:44:43 2019 daemon.err odhcp6c[2096]: Failed to send DHCPV6 message to ff02::1:2 (Address not available)
Mon Aug 5 15:44:43 2019 daemon.notice netifd: Interface 'wan6' is now down
Mon Aug 5 15:44:43 2019 daemon.notice netifd: Interface 'wan6' is setting up now
Mon Aug 5 15:44:43 2019 daemon.err odhcp6c[5680]: Failed to send RS (Address not available)
Mon Aug 5 15:44:46 2019 daemon.notice netifd: wan (5627): udhcpc: sending discover
Mon Aug 5 15:44:49 2019 daemon.notice netifd: wan (5627): udhcpc: sending discover
Mon Aug 5 15:44:54 2019 daemon.err odhcp6c[5680]: Failed to send RS (Permission denied)
Mon Aug 5 15:44:54 2019 daemon.notice netifd: VLAN 'eth0.2' link is down
Mon Aug 5 15:44:54 2019 daemon.notice netifd: Interface 'wan' has link connectivity loss
Mon Aug 5 15:44:54 2019 daemon.notice netifd: Interface 'wan6' has link connectivity loss
Mon Aug 5 15:44:54 2019 daemon.notice netifd: wan (5627): udhcpc: read error: Network is down, reopening socket
Mon Aug 5 15:44:54 2019 kern.info kernel: [ 168.220536] IPv6: ADDRCONF(NETDEV_UP): eth0.2: link is not ready
Mon Aug 5 15:44:54 2019 kern.info kernel: [ 168.226829] IPv6: ADDRCONF(NETDEV_CHANGE): eth0.2: link becomes ready
Mon Aug 5 15:44:54 2019 daemon.notice netifd: VLAN 'eth0.2' link is up
Mon Aug 5 15:44:54 2019 daemon.notice netifd: Interface 'wan' is setting up now
Mon Aug 5 15:44:54 2019 daemon.notice netifd: Interface 'wan6' is setting up now
Mon Aug 5 15:44:55 2019 daemon.notice netifd: wan (5627): udhcpc: received SIGTERM
Mon Aug 5 15:44:55 2019 daemon.notice netifd: Interface 'wan' is now down
Mon Aug 5 15:44:55 2019 daemon.notice netifd: Interface 'wan' is setting up now
Mon Aug 5 15:44:55 2019 daemon.err odhcp6c[5680]: Failed to send DHCPV6 message to ff02::1:2 (Address not available)
Mon Aug 5 15:44:55 2019 daemon.err odhcp6c[5680]: Failed to send RS (Address not available)
Mon Aug 5 15:44:55 2019 daemon.notice netifd: Interface 'wan6' is now down
Mon Aug 5 15:44:55 2019 daemon.notice netifd: Interface 'wan6' is setting up now
Mon Aug 5 15:44:55 2019 daemon.err odhcp6c[6007]: Failed to send RS (Address not available)
Mon Aug 5 15:44:55 2019 daemon.notice netifd: wan (6018): udhcpc: started, v1.28.3
Mon Aug 5 15:44:55 2019 daemon.warn odhcpd[1855]: DHCPV6 SOLICIT IA_NA from 00010001207976e978f29eef082a on br-lan: ok fdc3:d653:2dcd:10::da5/128
Mon Aug 5 15:44:55 2019 daemon.notice netifd: wan (6018): udhcpc: sending discover
Mon Aug 5 15:44:55 2019 daemon.err odhcp6c[6007]: Failed to send DHCPV6 message to ff02::1:2 (Address not available)
Mon Aug 5 15:44:56 2019 daemon.warn odhcpd[1855]: DHCPV6 SOLICIT IA_NA from 00010001207976e978f29eef082a on br-lan: ok fdc3:d653:2dcd:10::da5/128
Mon Aug 5 15:44:57 2019 daemon.warn odhcpd[1855]: DHCPV6 REQUEST IA_NA from 00010001207976e978f29eef082a on br-lan: ok fdc3:d653:2dcd:10::da5/128
Mon Aug 5 15:44:58 2019 daemon.notice netifd: wan (6018): udhcpc: sending discover
Mon Aug 5 15:44:59 2019 daemon.info dnsmasq-dhcp[2474]: DHCPDISCOVER(br-lan) 78:f2:9e:ef:08:2a
Mon Aug 5 15:44:59 2019 daemon.info dnsmasq-dhcp[2474]: DHCPOFFER(br-lan) 192.168.7.191 78:f2:9e:ef:08:2a
Mon Aug 5 15:44:59 2019 daemon.info dnsmasq[2474]: read /etc/hosts - 4 addresses
Mon Aug 5 15:44:59 2019 daemon.info dnsmasq[2474]: read /tmp/hosts/odhcpd - 1 addresses
Mon Aug 5 15:44:59 2019 daemon.info dnsmasq[2474]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Mon Aug 5 15:44:59 2019 daemon.info dnsmasq-dhcp[2474]: read /etc/ethers - 0 addresses
Mon Aug 5 15:44:59 2019 daemon.info dnsmasq-dhcp[2474]: DHCPREQUEST(br-lan) 192.168.7.191 78:f2:9e:ef:08:2a
Mon Aug 5 15:44:59 2019 daemon.warn dnsmasq-dhcp[2474]: Ignoring domain biegner.local for DHCP host name GdPAndy
Mon Aug 5 15:44:59 2019 daemon.info dnsmasq-dhcp[2474]: DHCPACK(br-lan) 192.168.7.191 78:f2:9e:ef:08:2a GdPAndy
Mon Aug 5 15:45:01 2019 daemon.notice netifd: wan (6018): udhcpc: sending discover
Mon Aug 5 15:46:46 2019 authpriv.info dropbear[10272]: Child connection from 192.168.7.191:58003
Mon Aug 5 15:46:56 2019 authpriv.notice dropbear[10272]: Password auth succeeded for 'root' from 192.168.7.191:58003
ifconfig -a
br-lan Link encap:Ethernet HWaddr E4:95:6E:46:91:EC
inet addr:192.168.7.1 Bcast:192.168.7.255 Mask:255.255.255.0
inet6 addr: fe80::e695:6eff:fe46:91ec/64 Scope:Link
inet6 addr: fdc3:d653:2dcd:10::1/60 Scope:Global
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:4785 errors:0 dropped:0 overruns:0 frame:0
TX packets:5397 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:556791 (543.7 KiB) TX bytes:2384410 (2.2 MiB)
eth0 Link encap:Ethernet HWaddr E4:95:6E:46:91:EC
RX packets:5034 errors:0 dropped:0 overruns:0 frame:0
TX packets:5576 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:731497 (714.3 KiB) TX bytes:2453840 (2.3 MiB)
Interrupt:4
eth0.1 Link encap:Ethernet HWaddr E4:95:6E:46:91:EC
RX packets:4789 errors:0 dropped:4 overruns:0 frame:0
RX bytes:556975 (543.9 KiB) TX bytes:2384410 (2.2 MiB)
eth0.2 Link encap:Ethernet HWaddr E4:95:6E:46:91:EC
RX packets:245 errors:0 dropped:8 overruns:0 frame:0
TX packets:165 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:83910 (81.9 KiB) TX bytes:45766 (44.6 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:278 errors:0 dropped:0 overruns:0 frame:0
TX packets:278 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:18396 (17.9 KiB) TX bytes:18396 (17.9 KiB)
teql0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
NOARP MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
wlan0 Link encap:Ethernet HWaddr E4:95:6E:46:91:ED
inet6 addr: fe80::e695:6eff:fe46:91ed/64 Scope:Link
TX packets:473 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:138609 (135.3 KiB)
wlan1 Link encap:Ethernet HWaddr E4:95:6E:46:91:EC
TX packets:481 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:139597 (136.3 KiB)
can you show the following as wel
lsusb
For E3276
ifconfig -a
RX packets:1303 errors:0 dropped:0 overruns:0 frame:0
TX packets:951 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:179895 (175.6 KiB) TX bytes:167472 (163.5 KiB)
RX packets:1350 errors:0 dropped:0 overruns:0 frame:0
TX packets:1042 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:222385 (217.1 KiB) TX bytes:195370 (190.7 KiB)
Interrupt:4
TX packets:77 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:22370 (21.8 KiB)
RX packets:128 errors:0 dropped:0 overruns:0 frame:0
TX packets:128 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:8704 (8.5 KiB) TX bytes:8704 (8.5 KiB)
TX packets:316 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:92278 (90.1 KiB)
TX packets:323 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:94889 (92.6 KiB)
lsusb
-ash: lsusb: not found
OK. Need to install usbutils first
opkg update
opkg install usbutils
lsusb
ls /dev
OK, testing Modem on MT300a → Tethering is shown…
root@GL-AR750S:~# lsusb
Bus 002 Device 003: ID 05e3:0752 Genesys Logic, Inc.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 05e3:0618 Genesys Logic, Inc.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@GL-AR750S:~# ls /dev
bus mtd3 ppp ttyS4
console mtd3ro ptmx ttyS5
cpu_dma_latency mtd4 pts ttyS6
full mtd4ro random ttyS7
fuse mtd5 sda ttyS8
gpiochip0 mtd5ro shm ttyS9
gpiochip1 mtdblock0 tty ubi0
hwrng mtdblock1 ttyS0 ubi0_0
kmsg mtdblock2 ttyS1 ubi0_1
log mtdblock3 ttyS10 ubi_ctrl
memory_bandwidth mtdblock4 ttyS11 ubiblock0_0
mtd0 mtdblock5 ttyS12 urandom
mtd0ro net ttyS13 usbmon0
mtd1 network_latency ttyS14 usbmon1
mtd1ro network_throughput ttyS15 usbmon2
mtd2 null ttyS2 watchdog
mtd2ro port ttyS3 zero
from lsusb, the device is not detected at all. It means the USB port does not work is is powered off.
Can you plug other USB devices e.g. usb storage to it?
The USB Power is controlled by GPIO. If you didn’t touch it, it should be enabled by default.
Also can you check if you have a powerful power adapter. The included 5V2A adapter should work.
I testet a 2.4 A Anker power supply and also an usb-powered hub.
If I put some other USB device (Memorystick) in it, no change.
So how can I check GPIO ??
Greets
Byte
his is mine.
root@GL-AR750S:~# cat /sys/class/leds/gl-ar750s\:white\:usbpower/brightness
0
root@GL-AR750S:~# cat /sys/kernel/debug/gpio
gpiochip0: GPIOs 0-31, parent: platform/ath79-gpio, ath79-gpio:
gpio-1 ( |gl-ar750s:white:powe) out lo
gpio-2 ( |reset ) in hi
gpio-5 ( |sda ) in hi
gpio-7 ( |gl-ar750s:white:usbp) out hi
gpio-8 ( |right ) in hi
gpio-19 ( |gl-ar750s:white:wlan) out lo
gpio-20 ( |gl-ar750s:white:wlan) out hi
gpio-21 ( |scl ) in hi
This GPIO 7 (usbpower LED) should be the USB Power control. It should output 0 when enabled
To enable USB Power if disabled
echo 0 > /sys/class/leds/gl-ar750s\:white\:usbpower/brightness
To disable
echo 1 > /sys/class/leds/gl-ar750s\:white\:usbpower/brightness
Same here:
cat /sys/class/leds/gl-ar750s:white:usbpower/brightness
0
gpiochip1: GPIOs 489-511, parent: platform/qca956x_wmac, ath9k-phy1:
gpio-490 ( |ath9k-phy1 ) in lo
Can you get an replacement and try?
I bought the GL-AR750S for a few days and diretly update it to Firmware version 3.025. I also checked the compatible list for the usb modems and bought the huawai E3276 to use it with the GL-AR750S. The usb modem should be found, but the connection should not be established.
lsusb:
Bus 001 Device 007: ID 12d1:1506 Huawei Technologies Co., Ltd. Modem/Networkcard
On the webIF The Model Name is empty and the IMEI is empty.
I can click on auto setup and it will not connect or if I enter the data of the Provider in manuel Setup, the connection will not establish.
The usb modem is working under Windows 10.
Whats wrong?
Your case is a little different. The modem is recognized. The mode and IMEI are not displayed and it is normal. Only quectel modems is supported.
Can you set up manually?
Pls share a screenshot of the settings?
Does the modem works in tethering mode? A screenshot should tell about this.
Finally if then modem works only in modem mode you can ssh to the router and set up using NCM which is Huawei protocol for its modems.
Try to search the forum and openwrt forum to have a check. I am on trip and cannot access internet for a while.
