Having trouble with my Huawei E3372 Hilink.
Could you pls recommend LTE modems that works well with the router?
Is there any documentation of supported modems?
Thanks
Thanks
What is the problem of E3372? Cannot recognized? Cannot connect?
According to the docs Internet - GL.iNet Docs E3372 is support.
It connects fine but I cannot access the modems web ui to change APN and check signal strength
I will discuss in your other thread.
