After the most recent software update for the GL-AR750S, the Wireguard VPN client no longer runs at startup. With the previous release, it properly loaded at startup, but now I have to manually start it.
Is there a way to make it run at startup again? Or find out what is causing it to not run?
I have the same issue with 3.100. When I reboot the router, the VPN client doesn’t start automatically. I have to login and manually start it each time.
Does it matter that I have multiple Wireguard client profiles configured? I would think that it would just re-establish the client profile that was last connected, but maybe that is what’s causing the issue?
I removed the other Wireguard client configs, and the issue persists. In Luci advanced config, the wireguard service is set to start, with priority 99. If I manually run this (/etc/init.d/wireguard start), then the VPN interface correctly comes up. So it seems that it’s not actually getting executed on startup.
Any ideas on what might be wrong? Any way to enable logging to get a better idea for why it’s not running? This is really frustrating because this router is setup at a remote location, and when the power goes out, there is no way to restore the VPN and someone has to physically go there and turn it back on.
