Good Morning,
i am new using a GL-AR750S. Everything is ready configured and
is running without problems.
But there is one Problem.
My System:
Master Network using Domains 192.168.10.100-200
Fritz!Box 192.168.10.1 (port forwarding rules enabled for Synology)
Synology 192.168.10.10 (Network using DNS 192.168.10.1 or 8.8.8.8
no specialized DNS in my Network
Synology OpenVPN installed and configured
OpenVPN Using 192.168.210.1 …
GL-AR750S
Router Modus actualy connected via WLAN (also testet via cable and at other internet)
IP 192.168.110.1
Using 192.168.110.100-200
Open VPN enabled and connects to OpenVPN Server at Synology
(so says the log an Syno and at GL-AR750S)
No my Problem:
I am surfing in the www without problems.
Also i can connect to intern IP Adresses - no Problem
But when i want to visit my Syno not via intern IP rather via
the dyndns Domain or SubDomain from my MasterDomain
i can not reach. “Site ist not reachable”.
Attached i will give you log from GL-Inet750S for VPN!
OpenVPN_log|690x138
Without OpenVPN there is noch Problem.
More Information:
I tested the OPENVPN config File with OpenVPN software
at WIN10 Tablett and it works without problems. Also the
surfing to my synology by using the dyndns Domain.
Has somebody an Idea where my problem is?
Huhie
