I set up an OpenVPN client to connect the router (GL-AR750S) to my home network. It works well, but I’d like to route only traffic destined for my home network through the VPN, leaving WAN traffic going through the wlan-sta interface. How can I acoomlish this? This is what my routing table looks like:
root@GL-AR750S:~# ip route
0.0.0.0/1 dev tun0 scope link
default via 192.168.156.33 dev wlan-sta proto static src 192.168.156.98 metric 20
10.33.0.0/16 via 10.36.1.1 dev tun0
10.33.0.1 via 192.168.156.33 dev wlan-sta
10.35.0.0/16 via 10.36.1.1 dev tun0
10.36.1.1 dev tun0 proto kernel scope link src 10.36.1.2
96.60.55.8 via 192.168.156.33 dev wlan-sta
128.0.0.0/1 dev tun0 scope link
192.168.8.0/24 dev br-lan proto kernel scope link src 192.168.8.1
192.168.156.0/24 dev wlan-sta proto static scope link metric 20
Also, I want to be able to connect from my home network back to the router over the VPN. This is possible by changing the Luci->Firewall->Zones->ovpn settings to accept/accept/accept for Input/Output/Forward. However, if I disconnect/reconnect the VPN, the setting reverts to the default of reject/accept/reject. How can I make this stick?
Thanks!
