I was trying to update all all packages just few min ago using (suggested command in other thread)
opkg update
opkg list-upgradable | cut -f 1 -d ’ ’ | xargs opkg upgrade
While update was performed I got some messages that are of a concern.
I am attaching file with both commands and output. At the end I did check dmesg for errors. Does anyone see anything wrong? Should I restore to factory? If I did it wrong what am I missing?
opkg-upgrade.txt.zip (2.4 KB)
EDIT: Then I rebooted and did try opkg update again. This time I ma getting
root@router:~# opkg update
Downloading http://downloads.openwrt.org/releases/18.06.1/targets/ar71xx/nand/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_core
Downloading http://downloads.openwrt.org/releases/18.06.1/packages/mips_24kc/base/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_base
Downloading http://downloads.openwrt.org/releases/18.06.1/packages/mips_24kc/gli_pub/Packages.gz
*** Failed to download the package list from http://downloads.openwrt.org/releases/18.06.1/packages/mips_24kc/gli_pub/Packages.gz
Downloading http://downloads.openwrt.org/releases/18.06.1/packages/mips_24kc/luci/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_luci
Downloading http://downloads.openwrt.org/releases/18.06.1/packages/mips_24kc/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_packages
Downloading http://downloads.openwrt.org/releases/18.06.1/packages/mips_24kc/routing/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_routing
Downloading http://downloads.openwrt.org/releases/18.06.1/packages/mips_24kc/telephony/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_telephony
Collected errors:
- opkg_download: Failed to download http://downloads.openwrt.org/releases/18.06.1/packages/mips_24kc/gli_pub/Packages.gz, wget returned 8.
Not sure why update is failing for some. I did factory(10 sec) restore and repeated above steps and get same results. Now at this stage if I try to update all again the units hangs and need to be rebooted. It downloads quite few packages but always it chokes at netifd_2019-01-31-a2aba5c7-2.1_mips_24kc.ipk. I get broken Pipe on ssh connecting ot this unit. I have to reboot the unit and I can ssh back to it.
At this point opkg update starts producing other errors:
Downloading http://downloads.openwrt.org/releases/18.06.1/targets/ar71xx/nand/packages/Packages.sig
/usr/sbin/opkg-key: line 56: usign: not found
Signature check failed.
Remove wrong Signature file.
Downloading http://downloads.openwrt.org/releases/18.06.1/packages/mips_24kc/base/Packages.sig
Downloading http://downloads.openwrt.org/releases/18.06.1/packages/mips_24kc/luci/Packages.sig
Downloading http://downloads.openwrt.org/releases/18.06.1/packages/mips_24kc/packages/Packages.sig
Downloading http://downloads.openwrt.org/releases/18.06.1/packages/mips_24kc/routing/Packages.sig
Downloading http://downloads.openwrt.org/releases/18.06.1/packages/mips_24kc/telephony/Packages.sig
Collected errors:
Is it something I am doing wrong here? Is this something should be reported to openwrt itself?
