When I plug in the power for the router the first LED lights up as normal however after that there is no activity at all. It seems like it’s stuck in a strange mode or something. I waited 10 minutes to see if anything would change but nothing happened. I tried factory reseting the router however, when holding the reset button nothing happens. The LEDs don’t flash or anything.
Can you try Debrick via Uboot?
The firmware can be downloaded from GL.iNet download center.
That worked thank you so much
